- 9,563
- 2,683
Tracer said:I respectfully disagree with you. I would like to provide additional details of the experiment which was proposed. However, If doing so will cause me to be locked out or banned I will just shut up and go away. What I have proposed is not speculation, a new theory, or an attempt to disprove anything. I am only proposing a test of which I think you misunderstood my description.
If you clarify your proposed experiment, you may get useful responses. It is fine to propose experiments for analysis.
This is the key phrase I was responding to is:
"then if the angle of aberration is the same for reversed positions of the viewing device"
What is angle of aberration? It is a difference from what is expected. But what is expected is simply either the result of a measurement in a different frame, or (in the actually used convention) the derived position imputed to the solar system frame based on collection angles observed over a year (or by applying a formula based on known speeds - but then you have not a measurement of aberration but a computation of aberration which is computed from the assumption of c). Thus, in one frame, all you can measure is 'where it is'. The minimum needed to measure aberration is two frames at different relative speed (you then have two angular positions to compare).
So, if you have something else in mind, you should clearly specify it.
