Continuous and differentiable function
The problem involves a function f: R -> R that can be expressed as the sum of an even function f1 and an odd function f2. The task is to demonstrate that if f is continuous, then f1 and f2 can also be chosen to be continuous, and similarly for differentiability.
  • Conceptual clarification, Mathematical reasoning
  • Participants discuss the definitions of even and odd functions and explore how to express f1 and f2 in terms of f. There is an attempt to derive expressions for f1 and f2 using f(x) and f(-x). Some participants express uncertainty about how to argue for the continuity and differentiability of f1 and f2 based on the properties of f.
Some participants have proposed expressions for f1 and f2 and are considering the implications of continuity and differentiability. There is ongoing exploration of relevant theorems related to continuous functions, but no consensus has been reached on the argumentation needed to support the claims about f1 and f2.
Participants note that if f is continuous, then f(-x) is also continuous, and they reference the sum and composition rules for continuous functions. However, there is a lack of clarity on how to formally establish the continuity and differentiability of the derived functions f1 and f2.
frankpupu
function f:R->R can be written as a sum f=f1+f2 where f1 is even and f2 is odd。show that if f is continuous then f1 and f2 may be chosen continuous, and if f is differentiable then f1 and f2 can be chosen differentiable
2. The attempt at a solution
i have try some examples, but i still cannot get the idea from that
You should be able to find an expression for f1 and f2 given f. Think about f(x)+f(-x) and f(x)-f(-x).
Given function f, let [itex]f_e(x)= (f(x)+ f(-x))/2[/itex] and [itex]f_o(x)= (f(x)- f(-x))/2[/itex].
yes f(x)=((f(x)+f(−x))/2 )+(f(x)−f(−x))/2) then (f(x)+f(−x))/2 is even and (f(x)−f(−x))/2 is odd,then i don't know how to argue their continuity and differentiability?
I don't think you have to prove it from scratch. If f(x) is continuous then f(-x) is continuous. What theorem about continuous functions might you use to prove that?
if f(x)is continuous then f(-x)is continuous ,(f(x)+f(-x))/2 is continuous by sum rule (f(x)-f(-x))/2 is continuous as well .but they should be chosen continuous
You are given f(x) is continuous. There is no need to show that. You do need to show f(-x) is also continuous. That's a composition rule. f(-x)=f(g(x)) where g(x)=(-x).
