Is the Standard Model a particle theory or a field theory?
The discussion revolves around whether the Standard Model (SM) of particle physics should be classified primarily as a particle theory or a field theory. Participants explore the implications of both perspectives, considering the nature of particles and fields, as well as the underlying mechanics of interactions in quantum theory.
  • Some participants suggest that the Standard Model can be viewed as a particle model, as it describes fundamental particles and bosons, while others argue that particles are merely excitations of underlying fields, indicating that the SM is fundamentally a field theory.
  • One participant posits that the physical objects in the SM are particles, with fields serving as a mathematical tool for description.
  • Another participant emphasizes that the notion of "particle" is a mathematical concept, applicable to both composite and point-like particles.
  • Concerns are raised about the nature of virtual particles and their role in interactions, with some participants expressing confusion about how particles interact without direct contact and questioning the initiation of virtual particle exchanges.
  • There is a contention regarding the interpretation of "spooky action at a distance," with some participants asserting that virtual particles do not represent this phenomenon, while others maintain that they do.
  • One participant argues that the objects measured in practice are particles, not fields, while another counters that the theory itself is fundamentally about fields.
Participants do not reach a consensus on whether the Standard Model is a particle theory or a field theory, with multiple competing views expressed throughout the discussion.
Participants express uncertainty regarding the nature and mechanics of virtual particles, the concept of measurement in relation to fields and particles, and the implications of quantum theory on interactions.
jnorman
just looking at the standard model, which describes a host of fundamental particles and bosons, one could assume that the SM is a particle model. however, most of what i read appears to indicate that particles are merely "excitations" or manifestations of a field, and it has been stated on this forum that SM is a field theory. this field explanation seems to make sense, since what we consider fundamental "particles" like quarks and leptons, are all point particles with zero volume - ie, there is "no-thing" there, only properties.
at the same time, science has no idea of how a field operates, and apparently is built on "spooky action at a distance", since no particles ever actually come into direct contact to impart changes in momentum or energy - they conduct these exchanges via "virtual" particle exchange (magic?).
what is your particular view of this? is SM a particle theory or a field theory? thanks.
I would say that SM is a quantum theory of particles described by the aid of quantum fields. In other words, the physical objects are particles, while the fields are a mathematical tool.
By the way, the "spooky action at a distance" in quantum theory has nothing to do with virtual particles.
Also the notion of "particle" is a mathematical notion, may it be a composite particle or a point-like particle.
I would say that it is a field theory.
Why would you say that?
demyst - if virtual particles don't represent spooky action at a distance, i don't know what does. i know i am pulling a metaphor here, but the way particles interact, while very well modeled mathematically, is simply baffling from a "how does that happen?' perspective.
Virtual particle exchange is actually a great explanation of causality, since it explains why interactions cannot be transmitted faster than light. It's actually not at all like spooky action at a distance. It is inherently quantum mechanical though, since the effect of a virtual particle will not be known unless a measurement is made on the system.
fz - how does one particle know that another particle is nearby and necessitates the exchange of virtual particles? how is the exchange of virtual particles initiated? what are virtual particles? maybe that is all clear to you, but i sure don't understand it.
EPR correlations.
Because in SM the objects we MEASURE in practice are particles, not fields. Moreover, fermionic fields cannot be measured even in principle.
That is irrelevant, the question is what the theory says, and QFT is a theory of fields.
  • · Replies 26 ·
