Calculating Gamma Coincidence Likelihood
  • Context: Graduate
  • Thread starter Thread starter nlieb
    coincidence Gamma
The discussion focuses on calculating the Gamma Coincidence Likelihood using two detectors positioned equidistant from a gamma source. The likelihood of simultaneous gamma hits at each detector is influenced by the detectors' sizes and the gamma production rate. Perturbed Angular Correlation Spectroscopy (PAC) is highlighted as a relevant method for this analysis, particularly when considering the orientation of nuclei, which affects gamma emissions. The discussion emphasizes the necessity of low temperatures (milliKelvin) for observing asymmetries in uncorrelated emissions.
  • Understanding of gamma decay and its directional symmetry
  • Familiarity with Perturbed Angular Correlation Spectroscopy (PAC)
  • Basic knowledge of condensed matter physics
  • Concept of detector size and its impact on coincidence likelihood
  • Research the principles of Perturbed Angular Correlation Spectroscopy (PAC)
  • Study the effects of detector size on coincidence detection in gamma spectroscopy
  • Explore the relationship between temperature and gamma emission asymmetry
  • Investigate mathematical models for calculating coincidence likelihood in particle detection
Researchers in nuclear physics, physicists specializing in gamma spectroscopy, and anyone involved in experimental setups using gamma detectors will benefit from this discussion.
nlieb
So we know gamma decays are directionally symmetric, but assume we have two detectors and we want to know the likelihood of two γs hitting each detector at the same time as a function of the angle between the line connecting the first detector and the source and the line connecting the second detector and the source. Assume the detectors are equidistant from the source. Obviously, the likelihood has to be related to the size of the detector and to the rate at which the γs are being produced, since if the detectors were infinitesimally sized the only coincidences would be either a result of two separate decays or would occur at [itex]\theta[/itex]=[itex]\pi[/itex] radians. How might we go about doing this?
Check out Perturbed Angular Correlation Spectroscopy (PAC). I'll post a good link when I find one...
[edit] Oh, I forgot: When you orient the nuclei, the gamma emissions are not isotropic (directionally symmetric) anymore. But you need very low (milliKelvin) temperatures for that.
To observe PAC you don't necessarily need very low temperatures. That you need only if you want to observe an asymmetry of the uncorrelated emissions.
This one is quite good, but you need a bit of background knowledge in condensed matter physics.
http://physik2.uni-goettingen.de/research/2_hofs/methods/pac
This one give more of the gory details.
http://www.ias.ac.in/pramana/v70/p835/fulltext.pdf
  • · Replies 0 ·
  • · Replies 41 ·
  • · Replies 29 ·
13K
11K
  • · Replies 62 ·
13K
