Is this a canonical transformation?
  • Thread starter Thread starter Liquidxlax
    Proof Transform
This discussion focuses on the conditions for a transformation to be canonical in phase space, specifically through the change of variables defined by the smooth and invertible function f. The transformation from (q,p) to (Q,P) is established using the relations Pj = (∇f-1)Tjk(f(q))pk. The participants clarify that for the transformation to be canonical, the conditions (dQi/dqj)(q,p) = (dpj/dPi)(Q,P) and (dQi/dpj)(q,p) = -(dqj/dPi)(Q,P) must hold true. The discussion also addresses the role of the transpose in the Jacobian matrix and confirms that the transformation is indeed canonical when the matrix multiplication MJMT = J is satisfied, where J is the symplectic matrix.
  • Understanding of canonical transformations in Hamiltonian mechanics
  • Familiarity with symplectic geometry and the symplectic matrix J
  • Knowledge of gradient and Jacobian matrices, specifically (∇f-1)Tjk
  • Proficiency in calculating Poisson brackets and their properties
  • Study the properties of symplectic matrices and their applications in Hamiltonian mechanics
  • Learn about generating functions in canonical transformations and their explicit forms
  • Explore the implications of Poisson brackets in phase space transformations
  • Investigate the symplectic method and its role in proving canonical transformations
Physicists, mathematicians, and students specializing in classical mechanics, particularly those focusing on Hamiltonian dynamics and phase space analysis.
Liquidxlax
Consider the following change of variables in phase space f: maps the reals and is smooth and invertable change of coordinates Q=f(q), q = f-1(Q). Given f, define a change of variables on phase space (q,p) -> (Q,P) by the pair of relations
q runs from 1 to n
show that its canonical.
I know that for this to be canonical
(dQi/dpj)(q,p) = -(dqj/dPi)(Q,P)i'm having a couple problems, is f the generating function that i have to find explicitly?
Can i use the sympletic method such that MJM^T = J
what is the point of the transpose for the (∇f-1)Tjk part for? i thought f had to be symmetric.
for Pj it can equal
(∇f-1)TjkQpk
=(∇f)T *-1jkqpk
but for that to be true then (∇f-1)Tjk has to be symmetric therefore the transpose dissapears
looking at my notes, i think this is supposed to be the associated point transformation in phase space
Guess i can answer my own question... i knew how to do it but i had an error in my notes
[dQ, dP)T = [{dQ/dq, dQ/dp}, {dP/dq, dP/dp}]*[dq, dp] = Mij*[dq, dp]
to prove its a canonical transformation
MJMT = J where J = [{0,I},{-I,0}] and T represents the transposeIf i do the matrix multiplication and say:now i will let {a,b} where a and b are some arbitrary coordinates be the poisson brackets
MJMT = [(0,{Q,P}), (-{Q,P},0)]
It is known that {P,P} = 0 = {Q,Q} and {Q,P} = δij
Using the following vvvv
and there you have it
