Conductivity in a one-dimensional chain of flourine atoms
The discussion centers on the conductivity of a one-dimensional chain of fluorine atoms, exploring the implications of the Fermi level's position in relation to the band structure. Participants consider how variations in ionization states (F-, F+, F2+) affect conductivity and the nature of the material, including comparisons to other elements like oxygen and neon.
  • One participant suggests that if the Fermi level lies in the conduction band, the material could conduct electricity, but questions arise about the stability and implications of using F- or F+ ions.
  • Another participant notes that a half-filled band could indicate metallic behavior, but introduces the concept of Peierls distortion, which could alter this behavior in one-dimensional systems.
  • A participant expresses the belief that the band gap exists where the density of states is zero, questioning whether the presence of unoccupied bands in the case of F+ would still allow for metallic conductivity.
  • There is a suggestion that F2+ might have similar band structure characteristics to F+, raising questions about the implications for conductivity.
  • One participant argues that even without Peierls distortion, the chain would likely behave as a Mott insulator due to strong electronic correlation effects, complicating the conduction process.
  • Another participant proposes considering isoelectronic chains of oxygen or neon instead of fluorine ions, suggesting that these alternatives would provide clearer insights into insulating behavior.
Participants express differing views on the conductivity of the fluorine chain and the effects of ionization states, with no consensus reached on the implications of the Fermi level's position or the stability of the proposed systems.
Participants acknowledge limitations related to the stability of certain ions and the complexities introduced by electronic correlation effects, which may influence the expected behavior of the materials discussed.
bushman00
If we prepare a chain of flourine atoms: F-F-F-F-F-F-F-F-F-F-F-F-F-F-F-F-F-F-F we can construct the band structure shown. I'm using flourine as an example but my question can be generalized: What do we know about the conductivity of a material (such as this 1D chain) when the fermi level lies in the conduction band, ie. above the band gap? I'm also curious how the fermi level would rise and fall if this chain would have been constructed from F- or F + ions. I imagine with the F- ion because all the bands are filled, the structure is most certainly insulating but where would F+ lie?
BM
The idea of a band gap normally refers to the difference in energy between an entirely full (valence) band and an entirely empty (conduction) band. Here, since you have a half-filled band, the system would be metallic if you believe the simplified band structure diagram you’ve attached. (In fact, one-dimensional metals will spontaneously undergo a distortion that makes them insulating – google “Peierls distortion” for more on this if you’re interested.)
As for your second questions: where do you think the Fermi level would fall in a hypothetical chain of F+ ions? (Note of course that this would be unstable in real life since it would carry an infinite amount of charge!)
Thanks for the response, I'm under the impression that the band gap exists in a region whereby bands don't overlap or in other words where the density of states is 0. So to some degree what you're saying must be an extension of this principle?
Considering the fermi level for a chain of F+ I would presume it would lie slightly below its placement for the F chain, at the level of the degenerate pi orbitals. But what does this imply about its conductivity? It still overlaps the pz sigma character band (that is now unoccupied) so doesn't this make it a metal?
To extend this concept a bit further, wouldn't F2+ (ignoring infinite charge) also lie in the same place as F+ because there would still exist one fully occupied pi degenerate orbital? I believe that S would also share a similar chain band structure as F+ as well but without the infinite charge to make the theory a little less fictitious. Thanks,
BM
Even if the chain of fluorine (not flourine) atoms were stable against Peierls distortion, it would probably not be a conductor but a Mott insulator. A one-electron band structure does not allow you to decide whether a substance will be a conductor when there are strong electronic correlation effects. In the process of conduction, electrons would have to hop independently from one atom to the next, thereby creating F^+ F^- pairs, which is very awkward due to the high electronegativity of fluorine.
Instead of considering a chain of F^+ or F^- I would consider a chain of isoelectronic O or Ne atoms, respectively. Ne is certainly an insulator and O too.
  • · Replies 21 ·
82K
