Deposition of salt from evaporated water
  • Context: Undergrad
  • Thread starter Thread starter papernuke
    Deposition Salt Water
The discussion focuses on the phenomenon of salt deposition from evaporated sodium chloride (NaCl) solutions. When a 5ml saturated NaCl solution evaporates on a flat surface, the salt consistently accumulates at the outer edges rather than forming a uniform distribution. This behavior is attributed to temperature gradients across the surface during evaporation and the varying rates of water movement, which lead to higher concentrations of salt at the edges where the solution was initially placed.
  • Understanding of saturated solutions and solubility principles
  • Basic knowledge of evaporation processes
  • Familiarity with temperature gradients and their effects on liquid behavior
  • Concept of concentration gradients in solutions
  • Research the effects of temperature distribution on evaporation rates
  • Explore the principles of solubility and saturation in different solvents
  • Investigate the role of surface area in evaporation and crystallization
  • Learn about the physics of concentration gradients in liquid solutions
Chemistry students, researchers in physical chemistry, and anyone interested in the crystallization processes of salts from solutions.
papernuke
When a small volume, say 5ml, of saturated solution of NaCl is left on a flat surface and evaporates, why does the salt always become concentrated on the outer edge of the base where the solution was? Why doesn't it form a uniform distribution of salt throughout the entire area which the solution previously took?
It could be something to do with the temperature distribution over the surface (due to evaporation) or the rate of water movement where the liquid is more shallow - the outside edge being a bit more concentrated..
  • · Replies 20 ·
25K
  • · Replies 32 ·
