How don't neurons get enough K+ to balance out their inner negative charge?
The discussion centers on the mechanisms of ion movement across neuronal membranes, specifically focusing on potassium (K+) and sodium (Na+) ions in relation to resting membrane potential and action potentials. Participants explore the forces at play, the role of ion channels, and the function of the sodium-potassium pump, delving into both theoretical and conceptual aspects of neuronal function.
  • Some participants argue that if resting potential is negative, K+ ions should not be passively exiting the cell, likening it to an attraction scenario.
  • Others propose that the firing of neurons depends on K+ not being inside the cell, suggesting that a sudden influx of K+ is crucial for neuronal firing.
  • One participant emphasizes the importance of understanding contradictions in biology rather than accepting that "things wouldn't work otherwise."
  • It is noted that two forces influence K+ movement: the electric force pulling K+ in due to the negative charge inside the cell, and the diffusion force pushing K+ out due to higher concentration inside the cell.
  • Some participants discuss the permeability of the membrane to K+ and Na+, suggesting that Na+ is repelled by the positive charges outside the cell, but permeability factors must also be considered.
  • There are claims that the membrane has negligible permeability to K+ at rest, and that K+ permeability increases only after Na+ influx.
  • Several participants describe a sequence of events leading to action potentials, detailing the roles of Na+ and K+ channels and the sodium-potassium pump in maintaining membrane potential.
  • One participant questions the functioning of the Na+/K+ pump if Na+ channels are closed at rest, suggesting that the pump may not be able to find sodium ions to transport.
Participants express multiple competing views regarding the mechanisms of ion movement and the functioning of ion channels and pumps. The discussion remains unresolved, with no consensus on certain aspects, particularly regarding the conditions under which the sodium-potassium pump operates.
Participants highlight various assumptions, such as the conditions under which ion channels open and the implications of membrane permeability. The discussion also reflects on the complexity of ion gradients and the interplay between electrical and concentration forces.
sodium.dioxid
If resting potential is negative, then K+ ions shouldn't be passively exiting the cell. It doesn't make sense for a male that is attracted to females to leave a club full of females and go outside where there are lots of males. There are females to be had!
Biology news on Phys.org
The neuron's firing depends on the K+ not being inside. The sudden rush of K+ is what causes the firing. Neurons wouldn't work otherwise.
There are two levels to learning anything in biology. One is by saying that "things wouldn't work otherwise". The other level is trying to understand the seeming contradictions. THAT is the one I'm interested in.
There are two forces at work here:
1. Electric force--because the inside of the cell is negative, it pulls K+ in.
2. Diffusion force--because the concentration of K+ is much, much higher inside the cell, K+ tends to move out. This is because things move from regions of high concentration to regions of low concentration, like a drop of food coloring spreading out in a glass of water.
In the resting state, the diffusion force (pushing K+ out) is much stronger than the electromotive force (pulling K+ in), so K+ moves out of the cell.
In terms of gradients: the concentration gradient pushing K+ out is stronger than the electrical gradient pulling K+ in.
(And by the way, K+ doesn't create the action potential; Na+ does.)
But if the external side is positive by the presence of positive ions across the membrane, why Na+ ions are not stopped/repulsed by them since the electrostatic force that exists in the extra cellular compartment near the membrane is stronger that the ones that may exist on the other side of the membrane?
Na+ IS repelled by the excess of Na+ and other positive charges. Only you have to factor
in permeability.
Neurons are designed to maintain a negative resting membrane potential. Meaning they have
channels that open only at specific threshold voltages. Extracellular signals at the synapse
stimulate the opening of ion channels making the synapse more "permeable" to these
specific ions. If the voltage within the cell reaches a specific threshold, voltage gated Na+
channels open allowing an all or none (non-decrementing) action potential.
So there can't simply be an influx of ions into or out of the cell. You need channels to
open to allow permeability. There are diverse types of channels. One's that respond to
mechanical pressure, light, vibration, voltage, chemical signals etc.
There are no contradictions, there is only a balance of polar opposites.
Understand equilibrium and you will understand biology.
yin and yang
in permeability.
If the membrane is permeable, at rest, to K+ there is an excess of K+ outside the cell. The Na+ ions will encounter them firstly when the membrane will change its state?
The membrane has negligible/leaky permeability to K+ at rest. K+ permeability increases
AFTER the influx of Na+
Also if the membrane is fully permeable to K+ then it won't be at the resting membrane potential. K+ will move out as it is less concentrated outside the cell, this efflux causes hyperpolarization of the cell (decreasing voltage below resting potential Vr).
as "aytell" stated already there are 2 forces at work.
One caused by the the concentration gradient, the other by the voltage (charge difference).
There are a sequence of events happening.
1. Some stimulus (light/acoustic/mechanic/ligand/etc) mediated voltage increase causes threshold level voltage.
2. At this threshold Na+ channels are frequently open and allow influx from outside (positive
and high in Na+ concentration) to the inside (negative and low in Na+ concentration). This
known as the rising portion of the action potential (also called depolarization)
3. Increasing voltage due to Na+ influx triggers the opening voltage gated K+ channels, resulting in a net efflux of K+ from the cell. Against its electrical gradient (- to +) and towards its concentration gradient (high to low concentration). The concentration gradient dominates over the electrical gradient in this circumstance, resulting in the falling phase of
the action potential and slight hyperpolarization.
The movement of ions is determined by the Goldman equation. It is the net sum
that determines the fate of all ion movements.
In a healthy animal cell Na+ permeability is about 5% of the K permeability or even less, whereas the respective reversal potentials are +60 mV for sodium (ENa)and -80 mV for potassium (EK). Thus the membrane potential will not be right at EK, but rather depolarized from EK by an amount of approximately 5% of the 140 mV difference between EK and ENa. Thus, the cell's resting potential will be about −73 mV.
From Resting Potential
And, if Na+ channels are closed at rest and permeability to K+ at rest is near to 1 then the Na+/ K+ exchanging pump may not function at all?
If a theoretical model is clear/simple you must/may be able to draw every step between each phase. In that case, I can't draw it.
Na+/K+ pump is an ATPase
Phosphate bond hydrolysis ΔG=−30.5 kJ/mol
it pumps 3 Na+ and 2 K+ against their respective electrochemical gradients.
this is a form of active transport and does not depend on the gradients unless the
energy stored in a phosphate bond is comparable to the gradient differential.
In order to maintain the cell membrane potential, cells keep a low concentration of sodium ions and high levels of potassium ions within the cell (intracellular). The sodium-potassium pump moves 3 sodium ions out and moves 2 potassium ions in
From Na/K pump
At rest Na+ channels are closed so no Na+ is entering the cell.
The pump can not function.
somasimple said:
From Na/K pump
The pump is not the same protein as the receptor that operates the Na flood channels. They're two completely different kinds of gateways in/out of the cell.
Yes, did I said something different? Does it change the problem?
Why do you think the pump cannot function?
At rest:
Na+ channels are closed. Sodium intake may be quite low.
K+ channels are open so potassium ions goes out.
Na/K pump is theorized as functioning all the time.
If sodium intake is meant low and potassium outtake is meant high, how a pump that may put outside 3 Na+ (taken from inside) and may put inside 2 K+ (taken from the outside) find sodium ions, inside, when they remain outside because the sodium permeability is low?
http://highered.mcgraw-hill.com/sites/0072495855/student_view0/chapter2/animation__how_the_sodium_potassium_pump_works.html
This animation does not provide any clue how Na+ ions entered in the cell.
EdwardFrank said:
What is a relation of biology and nutrition ?
What is the relation with this question and the subject?
Sodium is still there even if "low" so it can still be pumped out and there are also always leak currents that ignore channel gating.
That's a wise response but the contribution of Na/K pump was known as already low in a resting potential.
If its contribution is low at rest, it may not change when the neurons fires since it depends of ATP. Thus, you get another problem: The recovery phase becomes too long since Na+ (voltage gated) are still closed since the end of the rising phase...
I still don't understand what you're trying to say, the pumps is always operating (yes, through ATP); it doesn't need to "change".
Perhaps you are imagining much more Na floods in then actually does? It doesn't require a lot to depolarize the cell. The pumps are able to keep up with the help of leak currents which are always permeable and will go whichever way goldman-hodgkin-katz (the force balance) tells them to in the moment of the neuron's state.
Link is broken. But your picture is a reduction of Goldman to Nernst... It's valid depending on the question being asked.
It comes from the book Cells.
The text is demonstrating the concept of the Nernst potential. In a real neuron, there are several channels with different Nernst potentials; together they make the resting potential, so you can have a constant membrane potential maintained while Na leaks in and K leaks out through their respective channels; you would use the goldman-hodgkin-katz equation instead of Nernst in most dynamical cases.
I would yet stay with this simple example because the original Nernst equation belongs to Chemistry while the second belongs to Biology.
There is some major differences between the two equations :
In the original:
1/ There is a redox equation.
2/ The notion of concentrations is limited.
In Biology:
1/ It introduces a semi permeable membrane.
2/ The notion of concentrations is not limited.
3/ It introduces charges that stick across the membrane: It belongs to Electrostatics.
4/ It introduces the notion of capacitor that belongs to Electricity.
5/ It introduces the notion of violation of Electroneutrality near the membrane.
Do you agree the text tells us that the potential depends of concentrations?
yes...
Pythagorean said:
yes...
Before I may answer a "yes", I will carefully examine if the hypothesis satisfy each scientific domain and its limitations:
Electrostatics:
1/ Each compartment contains negative and positive charges.
2/ The hypothesis creates an attraction from a charge contained in a compartment to the opposite:
The distance that exists between these two charges must be fewer than the distance that exists between opposite charges in a single compartment.
The membrane thickness must be thinner than the distance that exists between opposite charges in a single compartment.
These two conditions must be valid for each ion specie (Na+, K+, Cl- ...).​
These conditions are false because the point #1.
These conditions are false because the thickness is larger than the distance that exists between charges on each side.
Electricity:
since Electrostatics is not made possible then there is no capacitor effect.
It is also possible to discard this scientific field with the concentrations ratio.
Since these two first points are not validated then there is no reason that the electroneutrality rule may be violated.
You're not making much sense; is English your first language? I'm not sure if you don't know what you're talking about or you're just not communicating effectively, but it sounds like a lot of rubbish.
10K
10K
  • · Replies 19 ·
13K
  • · Replies 19 ·
