Tangential acceleration - radial acceleration
The discussion focuses on calculating tangential and radial acceleration for an object in uniform circular motion. The radius is 0.4m and the constant tangential velocity is 0.50m/s. It is established that the radial acceleration can be calculated using the formula V^2 / r, while the tangential acceleration is zero due to the constant tangential velocity. The angular acceleration is defined as α = dω/dt = d²θ/dt², confirming that no change in velocity results in zero tangential acceleration.
  • Understanding of uniform circular motion
  • Knowledge of tangential and radial acceleration formulas
  • Familiarity with angular acceleration concepts
  • Basic physics principles related to motion
  • Study the relationship between angular velocity and tangential velocity
  • Learn about centripetal force in uniform circular motion
  • Explore the effects of friction on circular motion
  • Investigate the implications of varying tangential velocity on acceleration
Physics students, educators, and anyone interested in understanding the dynamics of circular motion and acceleration calculations.
finitefemmet
Hi,
I got a ball in a circualar motion on a frictionless table and in a uniform circle.
I need to calculate the tangential acceleration and radial acceleration.
What I know:
Radius: 0.4m
Tangential velocity: 0.50m/s^-1 (constant)Are theese formulas right for this problem?
Radial acceleration = V^2 / r
Tangential acceleration = r*angular accelerationBecause I am confused when I mix tangential velocity with radial acceleration and so on.. and I need some help on how I can calculate the angula acceleration for the tangential acceleration.Every bit of information would help a lot!
Thanks
The tangential accelearation of a constant tangential velocity is always zero, because the change in velocity is zero. The formula for radial part is:
[itex]\alpha = \dfrac{\text{d}\omega}{\text{d}t} = \dfrac{\text{d}^2\theta}{\text{d}t^2}[/itex]
And for tangential :
[itex]\vec{a} = \dfrac{\text{d}\vec{v}}{\text{d}t} = \dfrac{\text{d}^2\vec{r}}{\text{d}t^2}[/itex]
Thanks that solved it for me;)
