Motion of a particle given position vector.
The problem involves analyzing the motion of a particle described by a position vector in three-dimensional space. The original poster seeks to demonstrate that the speed and magnitude of acceleration are constant, while also describing the nature of the motion.
  • Participants discuss deriving velocity and acceleration from the position vector and question the nature of the motion, including whether it resembles circular motion or a helix. There are inquiries about the correctness of calculations and the implications of the motion's shape.
Participants have provided guidance on considering the two-dimensional motion and its implications for the three-dimensional trajectory. Some have suggested plotting points to visualize the motion, while others have confirmed aspects of the original poster's calculations.
There is an ongoing exploration of the assumptions regarding the motion's shape and the relationship between the components of the position vector. The discussion includes considerations of how to demonstrate the nature of the motion without definitive conclusions.
tcanman
A position vector of a particle at a time t is r=icost +jsint +kt ; show the speed and the magnitude of the acceleration is constant. Describe the motion.
v = dr/dt
a = dv/dt
Could someone let me know if I am doing this correctly?
I derived the position to find the velocity:
v = dr/dt = -isint +jcost + 1k
Then derived the velocity :
a = dv/dt = -icost -jsint
Then found the magnitude of the acceleration:
mag(a) = sqrt ( cos^2(t) + sin^2(t)) = 1 , which is constant.
Motion- increasing oscillation? How would I show this?
Thanks!
Don't forget to find the speed (magnitude of the velocity).
Think about just the two-dimensional [itex]x,y[/itex] motion. What kind of motion would that be? Then notice that the [itex]z[/itex] component just linearly increases in one direction. What kind of shape will be created this way? And how will your particle move along that three dimensional shape?
I took the magnitude of the velocity and got sqrt( sin^2 + cos^2 +1) so sqrt(2) , so it would also be constant.
Would the particle just be moving around a circle? How could I prove this?
Thanks!
Well, yes for the two-dimensional case it would be circular motion. If you don't recognize the form, try picking various values of [itex]t[/itex] and plotting them on a two dimensional graph to see it.
Is it supposed to look like a spring? And was I correct about the velocity?
Thank you for the help.
Exactly, it's the shape of a helix. The motion is circular, but it's traveling upwards along the surface of a cylinder with time.
And yes, you were right about the speed.
Awesome! Thanks!
  • · Replies 30 ·
