Finding the unit normal of a vector field
The discussion revolves around finding the unit normal vector of a vector field, specifically in the context of calculus. Participants are exploring the implications of the unit normal being equal to k and its relation to curves parallel to the xy-plane.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants discuss the method for finding the unit normal vector, questioning why it equals k in certain cases. There are inquiries about the meaning of d sigma and its relation to area differentials.
Some participants have provided insights regarding the conditions under which the unit normal vector is k or -k, depending on the orientation of the surface. There is ongoing exploration of the meaning of d sigma and its calculation.
Participants mention that the problem states n = k, which raises questions about the assumptions made regarding the surface orientation. The discussion also touches on the implications of the curve being parallel to the xy-plane.
robertjford80
I'm on the last chapter of a 1200 page calc book, I'm really psyched.
The method I learned for finding the unit normal of a vector field, n, is take the derivative of the equation and divide that by the magnitude of the derivative. This technique works for questions 3 and 4 above, but for 1,2 and 5, the solution manual just says n = k. I can't figure out why n = k. What are they talking about?
I also need to know what d sigma = dxdy means.
dσ=dx dy simply means that the differential of area is equal to the differential of x multiplied by the differential of y.
Because the curve is parallel to the xy plane.
[itex]\hat n = \vec k[/itex] means that the unit normal vector is parallel to the z-axis, in this case, it is in the vertically upward direction.
what about d sigma?
how do you find n if the curve is parallel to the xy plane, does it just equal k?
Yes.
robertjford80 said:
what about d sigma?
d sigma is dx dy.
Or in other words, the curve is parallel to the xy plane.
n could be k or -k, depending on the orientation of the surface. n is the outward unit normal vector, and if the problem states "counterclockwise from above" then n is pointing upward, otherwise if it states ""counterclockwise from below"" then n = -k. If the surface lies in any plane (x=0, y=0 or z=0), then there are only 2 possible orientations for n, without any need for calculations, as you can deduce n directly.
If the surface lies in:
plane z=0, n is either k or -k
plane y=0, n is either j or -j
plane x=0, n is either i or -i
In all 3 cases, the positive value denotes moving along the positive direction parallel the respective axis, and similarly the negative value denotes moving in the negative direction parallel to the axis.
The OP said that the problem says n=k, so n is just k.
dimension10 said:
d sigma is dx dy.
but what does d sigma refer to? how do you calculate it? what does it mean?
##d\sigma## refers to the differential area, which when expressed in terms of Cartesian coordinates, converts to dxdy, as you are projecting the surface onto the x-y plane.
As sharks has said, it is the differential of area.
[tex]{\rm{d}}\sigma = \left\| {\frac{{\partial \vec r}}{{\partial s}} \times \frac{{\partial \vec r}}{{\partial t}}} \right\|{\rm{d}}s{\rm{ d}}t[/tex]
In your case, [itex]\left\| {\frac{{\partial \vec r}}{{\partial s}} \times \frac{{\partial \vec r}}{{\partial t}}} \right\| = 1[/itex] and ##s=x,t=y##
  • · Replies 85 ·
11K
9K
