Relativity: Proper time and length
The discussion focuses on the concepts of proper time and proper length in the context of relativity. Proper time is defined as the time interval measured in a reference frame where two events occur at the same location, while proper length is the length measured in a frame where the object is at rest. The forum also addresses calculations involving relative speeds, specifically how to determine the speed of a clock running at half the rate of a stationary clock and the speed of a meter stick observed to shrink to 0.25 m. Additionally, it discusses the relative velocities of two spaceships moving towards each other at 0.70c, emphasizing the importance of understanding these concepts through established formulas.
  • Understanding of special relativity concepts
  • Familiarity with the Lorentz transformation equations
  • Basic knowledge of velocity and speed calculations
  • Access to Halliday/Resnick/Walker physics textbooks
  • Study the Lorentz transformation equations in detail
  • Learn how to calculate proper time intervals using the formula Δτ = Δt√(1 - v²/c²)
  • Explore the concept of length contraction and its formula L = L₀√(1 - v²/c²)
  • Investigate relative velocity calculations in special relativity
Students of physics, educators teaching relativity, and anyone interested in understanding the principles of proper time and length in special relativity.
sydboydell31
(a) Write down the definition of proper time and explain how to use the appropriate formula with an example.
(b) Write down the definition of proper length and explain how to use the appropriate formula with an example.
(c) At what relative speed does a clock move if it runs at a rate that is one-half the rate of a clock at rest?
(d) At what relative speed does a meter stick move if its length is observed to shrink to 0.25 m?
(e) Two spaceships approach each other, each moving with the same speed as measured by a stationary observer on the Earth. Their relative speed is 0.70c. Determine the velocities of each spaceship as measured by the stationary observer on Earth.
i know that proper time/length means it's the time of an observer's own measurement, but how would you describe that using formulas?
Sorry but i really couldn't find any website/books with a good explanation. Thanks guys
All you'll have to understand is that the term is "proper time-interval" not "proper time".
the proper time interval is the time interval observed in a reference frame in which the two events that determines the time interval occurs in the same place. the proper length is the length measured in a reference frame with respect to which, the object whose length is to be measured, is at rest.
If you still don't understand, look up in Halliday/Resnick/Walker. it's helpful.
  • · Replies 44 ·
  • · Replies 67 ·
