Existent solution to the linear system Ax=b
The discussion revolves around the conditions under which a solution exists for the linear system Ax=b, where A is a symmetric matrix and c spans the null-space of A. Participants explore the implications of the orthogonality of vector b with respect to c and its relation to the existence of solutions.
  • One participant suggests that if b is not orthogonal to c, then a solution to Ax=b does not exist, prompting a formal demonstration of this claim.
  • Another participant proposes examining the expression (Ax)^T c, indicating that it could lead to insights regarding the relationship between Ax and c.
  • A different participant notes that if c spans the null-space, then any vector x would yield x^T Ac=0, raising questions about how this relates to the existence of solutions.
  • Further, a participant discusses the implications of A being an n-dimensional symmetric matrix and introduces the concept of decomposing a basis into components, suggesting that the zero vector c must be perpendicular to b for full rank.
  • There is a query regarding whether the implication that Ax is perpendicular to c follows from the earlier points made in the discussion.
Participants express differing views on the implications of orthogonality and the conditions for the existence of solutions, indicating that multiple competing perspectives remain without a consensus.
Assumptions about the dimensions of A and the properties of the null-space are present but not fully explored. The discussion also touches on concepts like rank and nullity without resolving specific mathematical steps.
onako
Suppose that the linear system Ax=b is given for some symmetric A, and it is known that vector c spans the null-space of A.
How could one formally show that if b is not orthogonal to c, the solution to the system Ax=b does not exist?
To remind you, the null-space of A contains all vectors u for which Au=0.
Think about
[tex](Ax)^T c[/tex]
where x is an arbitrary vector and c spans the null-space.
That would imply x^T Ac=x0=0. How do you relate this to the above problem?
Hey onako.
I'm assuming A is nxn (since you said it is symmetric). From this if c spans the null-space it must be an n-dimensional column vector.
From this you can use the decomposition argument that a basis can be broken into something and its perpendicular element (some books write it as v_perp + v = basis). Your zero vector c is perpendicular to b if you wish to have full rank.
If this is not the case, then you can show that you don't have full rank and that a solution should not exist. For specifics you should look at rank nullity, and for the v_perp + v = basis thingy, this is just a result of core linear algebra with spanning, dimension, and orthogonality.
Doesn't this imply that Ax is perpendicular to c?
  • · Replies 23 ·
