X-rays diffraction in a solid, Bragg's law
The discussion centers on determining the crystal structure of a cubic crystal using X-ray diffraction data and Bragg's Law. The angles provided (31.47º, 39.74º, 47.58º, 64.71º, and 77.59º) correspond to a wavelength of 1.54 × 10-10 m. The formula used is (λ/2a)² = sin²(θ)/(h²+k²+l²), where h, k, and l are Miller indices. The initial attempt to identify a body-centered cubic (bcc) structure yielded negative results, indicating the need for further exploration of possible Miller indices.
  • Understanding of Bragg's Law and X-ray diffraction principles
  • Familiarity with Miller indices and their significance in crystallography
  • Knowledge of cubic crystal structures, specifically body-centered cubic (bcc)
  • Basic mathematical skills for manipulating trigonometric functions and equations
  • Research the calculation of Miller indices for cubic crystals
  • Learn about the relationship between crystal structure and X-ray diffraction patterns
  • Study the implications of varying h, k, and l values in Bragg's Law
  • Explore software tools for simulating X-ray diffraction patterns from crystal structures
Students and researchers in materials science, crystallography, and solid-state physics who are analyzing crystal structures through X-ray diffraction techniques.
fluidistic
The X-rays diffraction diagramm of a cubic crystal shows lines for the following angles [itex]2 \delta = 31.47º[/itex], 39.74º, 47.58º, 64.71º and 77.59º when the X-rays have a wavelength of [itex]1.54 \times 10 ^{-10}m[/itex].
Determine the crystal stucture of the net, the Miller indices of the diffractive planes and the parameter of the net.
[itex]\left ( \frac{\lambda }{2a } \right )^2 =\frac{sin ^2 (\theta )}{h^2+k^2+l^2}[/itex] where h, k and l are Miller indices.
First I am not sure what they mean by "2 delta's". Second, it's the first time I'm asked to solve such an exercise and I've thought on it and I don't see a direct way to solve the problem, because I don't know the "parameter of the net", which I guess is "a" in the formula, nor do I know h, k and l.
So I've started a try. I've tested for a bcc crystal structure and the test resulted in a negative answer. Please tell me if my approach is correct.
I considered the angle \theta = 31.47º. From the given formula, I get [itex]a = \frac{\lambda }{\sin \left ( \frac{31.47}{2} \right ) } \approx 5.68 \times 10 ^{-10}m[/itex]. I considered h=2, k=l=0 because in a bcc crystal, h+k+l must be even.
I then tried h=k=2 and l=0 and I took the value of "a" I just obtained in order to see if I could find an angle close to 39.74º but I reached a value for theta of about 22.55º.
I realize that there are infinitely many other possibilities for the values of h, k and l for a bcc crystal structure so that I can't really affirm that the crystal isn't bcc. So how do I solve the problem? Should I work out a lot of possible values for h, k and l?
Is there a way to find the correct values of h, k and l without trying all possibilities? Thank you very much in advance.
9K
