Is there a simpler way to integrate this?
  • Thread starter Thread starter aruwin
    Integrate
The discussion revolves around the integration of a multivariable function, specifically the integral of \((x + y + z)^4\) over a defined rectangular volume. Participants explore various methods of integration and question the efficiency of different approaches.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the method of integrating each variable separately and the implications of doing so. There are questions about the correctness of specific steps and the handling of variables within the integrals. Some participants suggest substitutions and express confusion about the effects on limits of integration.
The discussion is ongoing, with participants providing guidance on integration techniques and clarifying misunderstandings. There is recognition of potential errors in calculations, and some participants are encouraged to share their work for further review.
Participants note the complexity of certain integrals, particularly when dealing with fractions and substitutions. There is mention of homework constraints and the need for careful attention to detail in calculations.
aruwin
Hi, I was wondering if there's a simpler way to integrate this? I got the answer by expanding one by one but that's such a long process! I got the answer 104/5 which is correct,though.
∫∫∫D (x + y + z)^4 dxdydz
D = {(x,y,z) | -1≤ x ≤1, -1≤y≤1, -1≤z≤ }
Hey aruwin.
For your integral, you are dealing with a simple rectangular volume, so the integral in its form is best evaluated by doing each variable separately at a time.
If you did it this way, then there's no point stressing about a better way to do it if you know and understand how to evaluate the integral.
you could keep in your head that the integral if (x+a)^n = (1/n)(x+a)^(n+1) if you wanted but there's nothing wrong with expanding everything out
chiro said:
Hey aruwin.
How do I do each variable sperately at a time? You mean like ∫dx∫dy∫dz ?
Ok,what about the function inside it? When say rectangle, it means
(x+y+z)2(x+y+z)2,right? But still,how do I integrate it like this?
You do it in the form of (x+a)^n with respect to dx and integrate out the x value. Then do the same for the y and the same for the z until you get a numerical quantity.
Since x,y,z are all orthogonal variables, you can do this with no problem just like you would integrated say xydydx by keeping one variable 'constant' and then integrating it with respect to the other.
OK,I am going to ask you something first, is this correct?
∫∫ (x+y+z)5/5 dydz
But what happens to the x inside the bracket?Shouldn't I do something about it?
∫∫ (x+y+z)5/5 dydz
take [itex]\int \int \int (x+y+z)^4 dx dy dz[/itex] and stick some brackets in there [itex]\int \int ( \int (x+y+z)^4 dx ) dy dz[/itex]
Substitute y+z = a
perform integration
substitute a = y + z
remove brackets
repeat
:biggrin:
Substitute y+z = a
perform integration
remove brackets
repeat
:biggrin:
Won't that change the range for dx?
nope, all you've done is substitute a for y + z as to avoid confusion, you've not touched x or dx at all (you haven't really altered anything)
It only changes the interval if the interval depends on those other variables.
To understand this, you need to understand orthogonality: things are orthogonal if changing one variable doesn't change another. We can write this in terms of dA/dB = 0 and dB/dA = 0 where neither change in accordance with the other variable.
If your limits were say from 0 to y^2 - z, then yes the limit would have to factor this in but because each variable is truly orthogonal, then this doesn't happen (in this case).
Substitute y+z = a
perform integration
remove brackets
repeat
:biggrin:
So I did what you told me but I didn't get the answer :( Tell me what is wrong here.
Check,please...
You wrote in your final step 27 instead of 2x17
Even so, I won't get the answer that is 104/5.
You made a major sign error in your integral:instead of + (-2 + z)^6 you wrote - (-2 + z)^6.
I will try again.But other than that,I'm doing this the right method,arent I?
Yes. I checked the answer with your calculation using a calculator: it gave 20.8 which is 104/5.
I calculated another 2 times but I didn't get the answer :( Are you sure my working there had only one mistake?
If you fix up changing the - (-2 + z) to + (-2 + z) and fix up your mistake with the 2^7 and make it 2*(-1)^7 and plug everything in correctly you will get 104/5. Show us your working so we can see what you did.
Oh,thank you!I got it,I got it!:-p
By the way, I have another question on multiple integration but must I create another thread or can I just continue in here?
Just post it in here, it's on topic and a simple continuation of the original threads premise.
This seems a little more complicated because there's fraction which is hard to decompose and I don't know how to decompose it anyway. Can you help me out with this one?
J = ∫∫D [(x-y)/(x+y)^3] dxdy
D = {(x,y) | 0 ≤x≤1, 0≤y≤1}
Try the substitution u = x - y, v = x+y. Remember to work out the Jacobian and the new limits.
I did it the other way,though. But I didn't get the answer that I am supposed to. Can you check for me,please?
The integral of y/(1+y)2 is not just -y/(1+y). You missed a term.
By the way, this is actually a pretty insidious integral. After you add the term you missed and get the result, try doing the integral in the opposite order (y first, then x). My earlier suggestion to try a substitution might not be a good alternate way to do this in light of this result.
Yes, I got it! The integral that I got is -1/2 but how come the answer that my professor gave is ∞? Is there any explanation to that?
Did you try doing the integration in the opposite order yet? (y first, then x). I suspect that your professor was not referring to the integral you just performed, but rather the integral of the absolute value of the integrand. To deduce that the integral of |(x-y)/(x+y)3| is infinity, you should do the integral you just solved in the order I suggested and understand what that result means.
  • · Replies 34 ·
