Prosthetic Leg explanations and advice.
  • Context: Medical
  • Thread starter Thread starter Thundagere
The discussion revolves around the design and functionality of prosthetic legs, particularly focusing on running mechanics and the potential for shock absorption in prosthetic designs. Participants explore various aspects of prosthetic technology, including materials, design considerations, and the implications for users, especially athletes.
  • One participant suggests creating a prosthetic leg that acts as a shock absorber to reduce pressure and injury risk while running.
  • Another participant questions how a runner could run on the balls of their feet with a prosthetic leg, referencing a specific design that allows for toe running.
  • Concerns are raised about the potential for tendon harm when running on toes, with a suggestion to design a prosthesis that facilitates a "heel-toe" running style.
  • There is a proposal to consider using blades on both legs for running, with a discussion on the balance and matching of prosthetic devices.
  • Participants express interest in the use of leaf springs in prosthetic designs, noting their advantages in stability compared to coil springs.
  • One participant reflects on the complexity of balancing prosthetic blades and the existing knowledge in the field, mentioning a controversy regarding competition fairness for double amputees using blades.
  • There is a discussion about the intersection of engineering and medical sciences in the context of prosthetic design.
Participants express a variety of viewpoints on prosthetic design, with no clear consensus on the best approach or specific technologies. Some participants support the idea of shock absorption, while others emphasize the benefits of existing technologies like leaf springs and blades. The discussion remains unresolved regarding the optimal design for running prosthetics.
Limitations include the lack of detailed technical specifications for the proposed designs, assumptions about user capabilities, and the dependence on individual preferences for running styles. The discussion does not resolve the effectiveness of different prosthetic designs or their impact on user performance.
Individuals interested in prosthetic technology, biomechanics, engineering applications in medical devices, and athletes using prosthetics may find this discussion relevant.
Thundagere
Yeah, I ask way too many questions.
Anyhow, I was reading on prosthetic legs and I noticed that one runner said he had to run on the balls of his feet with the prosthesis on. Having done this and suffered tendinitis due to too much tension when running, I thought about trying to make a prosthetic leg that tries to act as more of a shock absorber, to sort of relieve the pressure and make it easier to run and lower chances of injury.
This is what i was thinking of
http://img40.imageshack.us/img40/2817/p7190652.jpg
Possibly minus the bottom low spring constant springs. I was thinking of making it for the experience, try to get a better understanding of mechanics.
Essentially, the top part is stuck in the bottom part because of the triangles on the side. It rests on a high tension spring, so that the spring absorbs some of the shock from landing, but doesn't fold in.
Any advice on this? If it comes to anything I might try entering it in a science fair, but I'm not sure. Mainly I want the experience, so thanks for any advice!
Biology news on Phys.org
How would a runner with a prosthetic leg have a ball of his foot' on that leg?
Your diagram of a design using coli springs is testimony to the advantage of the leaf springs that many amputees use these days. They can be made with very good lateral stability whereas a coil spring always needs some sort of guide to provide the same stability.
Not on that leg. The article I was reading stated:
It has a custom, carbon-framed socket that attaches to his thigh, a metal knee and curving piece of plastic that acts as a foot with no heel, so Alan can run on his toes.
But the thing is, when you're forced to run on your toes it can harm your tendon. I'm wondering how one could create a prosthesis resulting in running "heel—toe" because while less efficient, it puts less stress on the tendon.
If this design is specifically for running then why not use blades on both legs? Plenty of able bodied people run around on blades and they seem to get on fine with practice.
If you're only missing one leg, then how would you put blades on both? It would unbalance you while running.
Also, can you elaborate on how leaf springs are used in prostheses? It sounds pretty interesting!
It would not be hard to balance the two blades, any more than to match a coil spring arrangement to a regular leg. Of course the two blades would need to be matched to the user - which could take a bit of time and effort. Else he would tend to run in circles. But this is all a known art. Just Google Running Blades.
There was recently a complaint that a double amputee should not be allowed to compete against regular runners because of the 'advantage' the blades gave him!
So what you're saying is that one person can have one real leg, with the other amputated, and still run with two legs?
Do you think this project is still worth doing, or should I try something else?
this looks more like engineering than actually physical biology etc etc. Is that something you are into
Yeah, it is. I actually posted this in the general physics section, but it was moved. Sort of like a crossover of engineering and medical sciences? Either way, I was hoping that someone could give me more info on this.
22K
  • · Replies 25 ·
  • · Replies 287 ·
29K
  • · Replies 21 ·
  • · Replies 21 ·
