Haloalkane hydrolysis - stoichiometric vs rate equation
  • Thread starter Thread starter Miffymycat
    Rate
The discussion revolves around the hydrolysis of tertiary haloalkanes, focusing on the stoichiometric equation versus the rate expression in the context of reaction kinetics. Participants explore the implications of different solvent conditions and the resulting concentration profiles over time.
  • One participant questions the validity of their sketch representing concentration versus time profiles for the reactants and products, particularly regarding the rates at which products are formed compared to reactants.
  • Concerns are raised about the conservation of mass, as the participant notes that the total moles of atoms do not seem to add up at the point of 50% conversion of RX to ROH.
  • Another participant suggests that if water and the haloalkane are equimolar, the reaction may not follow a first-order rate law, proposing an alternative rate expression that incorporates both reactants.
  • It is proposed that an ICE chart could clarify the relationships between the concentrations of RX, HX, and ROH as the reaction progresses.
  • There is a discussion about the common method of determining the rate expression through measuring changes in HX concentration, with a participant expressing concern that this method may not accurately reflect the behavior of RX under certain conditions.
Participants express differing views on the relationship between stoichiometry and kinetics, with some suggesting that the reaction may not adhere to a straightforward first-order rate law under specific conditions. The discussion remains unresolved regarding the implications of these observations on the overall understanding of the reaction.
Participants note that the stoichiometric equation may not accurately depict the molar ratios at all times during the reaction, as the reactants do not change in a 1:1 ratio throughout the process. Additionally, the dependence on solvent conditions and the treatment of water as a constant in the rate expression are highlighted as significant factors.
Miffymycat
This is a question about stoichiometry and rate expressions. Consider the hydrolysis of a tertiary haloalkane RX. The products are the alcohol ROH and hydrogen halide HX. Usually this is done in alcohol-water solvent, where the nucleophile, H¬2O, is in excess (a solvolysis reaction), allowing the order wrt to RX to be determined with effectively constant [H2O]. In order to make my point (and the graphic) more clearly, consider this reaction done under equimolar conditions in a dipolar aprotic solvent such as propanone, but the same principles/questions apply.
The stoichiometric equation is RX + H2O  ROH + H2O
The rate expression is Rate = k[RX]
We know that the [ ] vs time graph for a first order process is an exponential decay, and for a zero order a straight line. I have drawn the following sketch for the reactants and products (solvolytic conditions would show the H2O line at a much higher concentration and as a straight with just a tiny negative slope and therefore awkward to draw on the same axes):
see attached
Several questions arise:
1) Is my sketch a valid representation of the [ ] vs time profiles for all four substances? Are the 2 products formed at different rates, in the same way as the reactants? And does the linear graph for H2O have the same slope as the average slope for RX (and HX as for ROH)? ? Initially, [RX] is falling faster than [H2O] and vice versa towards the end. 50% conversion of RX has occurred where its curve crosses the ROH curve, since 1mol RX produces 1mol ROH – that seems not to obey conservation of mass - ie total moles of X (or O) atoms at that point do not then seem, to add up to the original amount!
2) So is it also correct to say that at any time t, the molar ratios are not as shown in the stoichiometric equation (because it is not depicting an elementary step) – since the reactants are clearly not changing in an equimolar or 1:1 ratio – and that it shows only the overall change at the end?
3) More interestingly, when studying the reaction kinetics, it is usual for the student to find the rate expression by measuring the change in [HX] by successive titration of withdrawn samples against standard base over time, or via pH sensor, and many textbooks/references say this. However, if these graphs are valid, this will not reflect the behaviour of RX and will give the wrong order (zero vs first)! Have I missed something?!
Chemistry news on Phys.org
A few notes:
a) If water and the haloalkane are present in equimolar amounts than the reaction may not follow a first order rate law. For example, the reaction rate could be given by rate = k[RX][H2O], but since [H2O] >> [RX], [H2O] can be treated as a constant that can be combined with the rate constant to get a new rate constant k' = k[H2O], such that rate = k'[RX].
b) It might be useful to make an ICE chart for the reaction, and find the amounts of each substance presence when [RX] changes by an amount y. This should show you the correct relationship between [RX], [HX], and [ROH]. Since y is small compared to [H2O], [H2O] stays essentially constant throughout the reaction.
Thanks again - useful input. I will continue to wrestle with it!
BTW, I could not manage to insert the Powerpoint png directly into the text of my question and had to attach it - how did you do it?!
I uploaded the image to a hosting server (I used tinypic.com) then used the img tags to insert the picture.
If you have any more questions after you give the problem some more thought, just let us know.
9K
