Wind turbine efficiency question
The discussion revolves around the efficiency of wind turbines, particularly focusing on the design of turbine blades and their ability to capture wind energy. Participants explore the mechanics of energy extraction from wind, comparing turbine blades to other designs like pinwheels, and consider factors such as blade shape, rotational inertia, and airflow dynamics.
  • Some participants question how slender turbine blades can effectively capture wind energy given that they occupy only a small fraction of the swept area.
  • Others propose that the speed of the blades relative to the wind allows for a significant amount of air to interact with the blades.
  • A participant mentions that lighter blades are necessary due to the consumption of wind energy by rotational inertia.
  • There is a discussion about the volume of disturbed air trailing behind the blades and how this affects the efficiency of subsequent blades.
  • Some participants compare wind turbines to pinwheel toys, noting that pinwheels have a larger surface area but are not designed for efficiency.
  • One participant explains that the force on the blades comes from changing the direction of the wind rather than being directly hit by it.
  • Concerns are raised about the efficiency of turbines that block significant areas, as this could prevent wind from passing through effectively.
  • Participants discuss the design differences between large wind turbines and smaller windmills used for agricultural purposes, suggesting different operational requirements influence design choices.
Participants express various viewpoints on the efficiency of wind turbines, with no clear consensus on the optimal design or mechanics involved. Multiple competing views remain regarding the effectiveness of slender blades versus larger surface areas.
Some claims about the mechanics of wind energy extraction depend on specific assumptions about airflow and blade design that are not fully resolved in the discussion. The relationship between blade design and efficiency remains complex and context-dependent.
Khashishi
If we look at wind turbines used for power generation, they typically have 3 blades, and the blades are very slender compared to the blades of a house fan. I don't understand how such a slender blade can capture a significant amount of the wind's energy. The energy available in the wind is proportional to the swept area under the blades. But it seems to me that only a small fraction of the circular area is actually occupied by a blade, so most of the air will just pass through the circle without hitting a blade.
So, how are these turbines able to extract a significant fraction of the available energy in the wind?
The rotational inertia has to consume some of that wind energy, so lighter is necessary
The blades move much faster than the wind. All the air that goes through will get close to a blade.
please explain how the rotational inertia consumes wind energy.
You can find the detailed answer here. The short answer though is that it's the same reason that glider planes have so long and slender wings.
If I understand it right, You'll find it explained there that the more blade surface is in the way, the more the air pressure accumulates in front of the blades, this will tend the air to flow outwards around the blades, which means loss of efficiency. That wind is simply lost. You want to minimize wing tip vortices, one way is to have the least possible amount of wing tips and that can be achieved by long slender wings.
Another effect, not there, is that the higher the wings can reach the stronger the windspeed. But that's maybe only a side effect.
Not on the big ones I see arrayed along hilltops. Lots of wind can get through the swept area after one blade passes and before the next comes by. If the bladetips swept closer to earth, even I could jump through safely (I think :wink: ).
The blades have a large volume of disturbed air trailing after them. You have to avoid the following blade getting involved with this disturbed air. So their effective size is a lot bigger than their apparent geometrical size.
The problem with all forms of turbine is that, once the energy has been transferred from the moving fluid, you still have to get rid of the fluid, downstream, to make room for the next lot. That means it must still be moving, representing unused Kinetic Energy.
This guy flies his RC-helicopter between the spinning blades (at 4:15), despite the turbulence.
https://www.youtube.com/watch?v=pz2zU5bNcaQ
This is a bit counter-intuitive, I guess but the sort of turbulence that would affect the efficiency wouldn't necessarily be high speed, wind-tunnel stuff, it would involve air speeds around the same as the normal wind speed. The helicopter should be able to handle that easily. The pilot still needs to have his wits about him though! You would feel a bit of a plonker if you flew into a blade.
Why is a pinwheel toy any different? It uses a lot of surface area to get hit by a lot of wind.
http://en.wikipedia.org/wiki/File:Green_pinwheel.jpg
Whatever the aerodynamic considerations, you certainly couldn't scale up a pinwheel toy design. The blades would be far too heavy. So one answer might be that you want a large catchment area but a light structure.
Pinwheel toys aren't really designed for optimum efficiency - they have other considerations. A maximally efficient pinwheel toy would look somewhat like a wind turbine, but the long, narrow blades would be quite a bit more fragile than the stubby, fat blades that they actually use. The narrow blades would probably make it more prone to having a small child poke him/herself in the eye too.
As stated above, the blades actually affect a fairly large region around them, so the end result is that a much larger fraction of the energy is extracted than you might think. They can never extract all of the energy, since as mentioned before, the air needs some residual velocity in order to allow for new air to flow in, but they can extract a pretty significant (and close to theoretically optimal) amount.
Does anyone know of experiments conducted to confirm the theory cited above?
The force on the blade doesn't come from it "being hit by the wind". It comes from changing the direction of the wind, (i.e. changing the momentum of the air flowing through the turbine.
The amount of air affected by the blade extends a long way out from the actual blade. in the same way that an airraft wing affects the airflow for a large distance above and below the wing (typcally many times the front-to-back length of the wing itself).
Apart from the increased weight, a turbine where the blades "block off" a significant amount of the area is less efficient because the wind doesn't go through the turbine at all - it just blows around the sides, the same as it would if there was a complete "blockage" like a building.
A pinwheel toy isn't designed to be efficient, but cheap to make. It doesn't have to produce any power except to overcome friction. For small wind turbines (e.g. less than 1 meter diameter) the total amount of power available is low anway, so if you can get say half the maximum theoretical efficiency for one tenth of the cost, that's a very good tradeoff. But for large turbines it pays to design them as efficiently as possible which is why they have a small number of carefully designed blades.
The blade tip speeds on big turbines is faster than you might think, looking at them from a distance. For a 40 meter long blade rotating at 10 rev/minute, the tip speed is more than 80 mph, which is a lot faster than the average wind speed.
Windmills used on farms to lift underground water have a swept area almost filled with vanes. http://www.thebackshed.com/windmill/articles/SouthernCross.asp Perhaps this reflects markedly different design criteria, with farm windmills being required to operate with almost daily regularity to ensure water tanks are kept filled. This means the mills are expected to turn during even slight breezes, since in inland areas brisker winds may be absent for months on end. Plunger-type water pumps have no minimum speed of operation, so even a slow-turning turbine is effective in raising water, albeit at a slow rate.
Let us consider a 10 m long board standing up in the wind. Near the board there is stale air. If this stale air is sucked or blown away from the board, large amounts of slowly moving air can be produced.
This is how a 10 meters tall and 0.1 meters wide board can slow down an air mass that is 10 meters wide and 10 meters tall.
One board moving at speed 10 m/s transverse to the wind causes the air to lose kinetic energy about the same amount as ten similar boards moving at speed 1 m/s transverse to the wind.
With fast moving narrow board compressed air can be produced from the wind. The small board exerts a large force on a large air mass, so there is a large air pressure near the board.
I agree. It is unlikely that the two solutions to the two different problems would be the same. Both styles of design are well tried and tested so it is not likely that either of them is fundamentally wrong. There must be a factor (perhaps just the size and consequent tip-speed) in the design of massive generators that dictates the use of a different approach.
  • · Replies 33 ·
  • · Replies 30 ·
