Plot unit circle in chebychev metric in MATLAB
This discussion focuses on plotting the unit circle using the Chebyshev metric in MATLAB, specifically utilizing the 'pdist' and 'cmdscale' functions. The user encountered issues with the dimensions of the resulting coordinates, where the variable 'y' incorrectly had a size of 360x180 instead of the expected 2xN format. Additionally, the plot produced resembled the Manhattan metric with rounded edges, indicating a potential error in the transformation process. The correct approach involves using the 'cmdscale' function to obtain eigenvalues and eigenvectors, which should be applied to generate the accurate plot.
  • Familiarity with MATLAB programming
  • Understanding of Chebyshev metric and its properties
  • Knowledge of multidimensional scaling techniques
  • Experience with plotting functions in MATLAB
  • Review MATLAB documentation for 'pdist' and 'cmdscale' functions
  • Learn about Chebyshev distance calculations in MATLAB
  • Explore eigenvalue decomposition and its applications in dimensionality reduction
  • Investigate common pitfalls in plotting metrics in MATLAB
Mathematicians, data scientists, and MATLAB users interested in geometric transformations and metric space visualizations.
meldraft
Ok, so I'm trying to plot the unit circle using the chebyvhev metric, which should give me a square. I am trying this in MATLAB, using the 'pdist' and 'cmdscale' functions. My uber-complex code is the following:
clc;clf;clear all;
boundaryPlot=1.5;
% Euclidean unit circle
for i=1:360
theta(i)=deg2rad(i);
end
zc=[cos(theta)' sin(theta)'];
% Transform to Chebychev metric
x=zc(:,:);
D=pdist(x,'chebychev');
D1=squareform(D);
y=cmdscale(D1);
% Plots
hold on
plot(y(:,1),y(:,2));
axis square;axis([-boundaryPlot boundaryPlot -boundaryPlot boundaryPlot])
plot([-boundaryPlot boundaryPlot],[0 0],'k')
plot([0 0],[-boundaryPlot boundaryPlot],'k')
where the part in bold is the really important part of the code. I have two problems with this. First, the 'y' variable which is supposed to hold the coordinates under the new metric has a size of 360x180. One of these dimensions should have been 2, which is the dimension of the L-p space (p=2).
My second problem is that I get the plot you can see in the attachment, which corresponds to the Manhatan metric, and has rounded edges for some reason.
Has anyone done this calculation before? Is there some other syntax/function I should be using??
The correct syntax should be:clc;clf;clear all;boundaryPlot=1.5;% Euclidean unit circlefor i=1:360 theta(i)=deg2rad(i);endzc=[cos(theta)' sin(theta)'];% Transform to Chebychev metricx=zc(:,:);D=pdist(x,'chebychev');D1=squareform(D);[V,L]=cmdscale(D1);y=V*sqrt(L);% Plotshold onplot(y(:,1),y(:,2));axis square;axis([-boundaryPlot boundaryPlot -boundaryPlot boundaryPlot])plot([-boundaryPlot boundaryPlot],[0 0],'k')plot([0 0],[-boundaryPlot boundaryPlot],'k')
