Help Requested: Reverse Engineering PCB Layout to Circuit Design
The discussion revolves around reverse engineering a PCB layout to create a circuit schematic for a charge controller. Participants share their experiences and techniques related to this process, emphasizing the hobbyist nature of the project.
  • Homework-related
  • One participant suggests starting by drawing out the components as a schematic and checking for interconnections, sharing their personal experience with similar projects.
  • Another participant inquires whether the original poster has the CAD layout or just an image, proposing that a connection report and BOM could facilitate schematic reconstruction.
  • There are mentions of the challenges involved in reverse engineering, including the need for concentration and proper lighting.
  • Participants express admiration for the work done by others, highlighting the effort involved in such projects.
Participants generally agree on the approach to reverse engineering PCB layouts, but there are no explicit resolutions or consensus on specific methods or outcomes.
Some participants reference the complexity of their past projects, indicating varying levels of experience and techniques used, which may influence their suggestions.
This discussion may be useful for hobbyists interested in reverse engineering electronics, particularly those working with PCB layouts and circuit schematics.
lostmind
Dear All
I have been recently started to work with Reverse Engineering technology and I would now like to determine a circuit layout diagram of a charge controller from its PCB Layout.
Can anyone please help me with this one. I have uploaded the PCB design for your reference.
Please note that this is purely a hobby project and I highly discourage commercial personalities business advice.
Thanking you all in advance
you just have to start somewhere at a point and start drawing out the components as a schematic. once everything is drawn out, and checked to make sure you haven't missed any interconnections then you can work on tidying up the schematic into something that looks easy to follow
I have done this so often over the years on substantially more complex ccts than that one of yours
Initially I will draw it out on paper and once I have a reasonable looking layout I will then use MSpaint ( paintbrush) to do the final drawing like you see below so I can store it on the puter for future reference
eg...
The first image the actual unit
the second image, a reasonable schematic
This board was particularly difficult as it was double layer
cheers
Dave
Its been one of those 10 year projects to put this unit onto the 24GHz amateur radio band, It may never happen as other ex commercial gear became available that was much easier to convert
here's another example I did some years back...
its takes some serious concentration magnifier lamp good backlight
but its often worth the effort
cheers
Dave
Dear Davenn thank you a lot for your replies...I am working on the circuit schematic...since this is my first one so I am a little bit confused...i made an initial draft last night and want to confirm whether it is correct or not...can you suggest me any ways to perform that ?
thanking you again
post a pic of the layout on here once you have tidied it up, and if I have time or some one else may get a chance to compare it with the PCb layout you gave above :)
Dave
Lostmind, Do you have the actual CAD of the layout or just the image? Can the CAD tool just print a connection report on all the nets and a BOM? Should be fairly straight forward to reconstruct a schematic from that information.
cheers
Dave
You have 'true grit' Dave. I'm very impressed! Much worse than the Guardian Crossword.
Yes, beautiful work Dave! :smile:
Nice indeed. I'm thinking the paint work was the hardest. :devil:
  • · Replies 16 ·
  • · Replies 23 ·
