Torque without pivot (Torque with only one force)
  • Context: Undergrad
  • Thread starter Thread starter cheahchungyin
    Force Pivot Torque
The discussion centers on the concept of torque and angular momentum in a scenario where a stick with uniform mass is dropped horizontally. Despite the presence of a net torque when selecting a pivot point on either end of the stick, it does not rotate due to the use of an accelerating pivot point. This highlights that angular momentum is not solely dependent on torque; rather, it involves additional terms that can cancel out the torque effect. The conversation emphasizes the importance of understanding angular momentum in relation to the conservation of angular momentum and the application of Steiner's theorem.
  • Understanding of basic physics concepts such as torque and angular momentum
  • Familiarity with the principles of conservation of angular momentum
  • Knowledge of Steiner's theorem (parallel axis theorem)
  • Ability to analyze motion in a two-dimensional space
  • Study the implications of Steiner's theorem in rotational dynamics
  • Explore the relationship between torque and angular momentum in various physical systems
  • Investigate the effects of different pivot points on the motion of rigid bodies
  • Learn about the mathematical formulation of angular momentum and its conservation laws
Physics students, educators, and anyone interested in understanding the principles of rotational dynamics and the behavior of rigid bodies under various forces.
cheahchungyin
Imagine, I drop a stick with uniform mass horizontally towards the ground. There is only one force acting on it, which is the weight.
By common sense, I would know that the stick will not turn. However, mathematically there is a net torque if I set the pivot point on either side of the stick.
So what's the problem here?
The problem is that you are using an accelerating point as your pivot. About such a point, the rate of change of angular momentum is not simply given by the net torque. There are other terms. (Which end up canceling that torque term, so you are left with no rotation. So your common sense was correct.)
The problem is, that angular momentum is a different concept than most people realize. If we talk about the conservation of angular momentum we mean the angular momentum off all moving mass around an arbitrary point in space. A point mass (which cannot rotate for more or less obvious reasons) flying past the origin at some distance has an angular momentum. A force acting on this mass will produce a torque changing the angular momentum. If you consider a stick centred at the origin that is hit by this mass it can start spinning an thus gain angular momentum from the point mass which loses it. The reason why we often only speak of torque and angular momentum around the centre of mass of objects is Steiner's theorem (aka. parallel axis theorem) which states that angular movements can be split into the rotation around an origin of an object's centre of mass plus the objects rotation around it own centre of mass.
  • · Replies 21 ·
  • · Replies 49 ·
  • · Replies 19 ·
  • · Replies 52 ·
