Predicting the distance where torque should be applied?
  • Thread starter Thread starter JazzyJones
    Applied Torque
The discussion revolves around calculating the mass of a meterstick using torque principles. The original poster describes an experimental setup involving a meterstick, a mass hanger, and the application of torque to achieve equilibrium.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the concept of torque and its calculation, questioning the distance from the pivot and the mass of the meterstick. There are attempts to relate the torque of the applied mass to the unknown mass of the meterstick through equations.
Some participants provide calculations for torque and suggest relationships between the known and unknown variables. There is a focus on ensuring the correct application of units and the relevance of certain distances in the calculations. Multiple interpretations of the setup and calculations are being explored.
Participants note potential confusion regarding the source of specific distance values and emphasize the importance of maintaining consistent units throughout the calculations.
JazzyJones
Finding the mass of the meterstick!
Distance was found through experimentation
I am given a mass hanger of 50g to place on a 100cm ruler held up on its center of mass at 49.8cm
I displace the clip holding the ruler by 15cm to the left. (assuming the ruler counts up from left to right) The experimental value in practice was 13.1cm for a balanced ruler. (How am I to calculate the assumed value?) With this information how am I to calculate the mass of the meterstick?
If not sufficient information is given or hard to imagine I could draw a picture and upload it.
Mass of ruler: 95.1 g
τ = rfsinθ
Ʃ F = 0
Ʃ τ= 0
I don't know what to plug in, I also think I am missing an equation. Trying to visualize the problem, I see how moving the clip to the left that I am increasing the torque in the problem, and to balance the meterstick, I must place the 50g mass at a certain distance to achieve equal amount of torque on both sides of the meterstick thus achieving equilibrium and a balanced meterstick. Am I missing something for finding the mass?
Hi JazzyJones ! :smile:
i] what is the torque of the 50 g mass?
ii] what is the distance of the centre of mass (from the pivot)?
iii] so what must the meterstick's mass be? :wink:
τ= mass*a*(distance from pivot)
τ= .05kg*9.8m/s^2*.0217m
τ= 0.010633
15cm or .015m
I'm taking a guess at this but what if I do this,
.05kg*9.8m/s^2*.0217m = m*9.8m/s^2*.015
right? because the net torque will equal 0
Hi JazzyJones! :smile:
(try using the X2 button just above the Reply box :wink:)
τ= 0.010633
15cm or .015m
Where does the 21.7 cm come from? :confused:
Apart from that, it looks right :smile:
the LHS is the torque of the 50g mass, and the RHS is the torque of the unknown m,
so now you just divide out to get m.
btw, you should leave g as "g" (instead of 9.8), since it'll cancel out anyway,
and you should leave everything in gram and cm (instead of converting to kg and m), since that'll cancel out also! :wink:
  • · Replies 30 ·
  • · Replies 26 ·
19K
