Is the solubility of a salt affected by how much salt you add to a solution?
  • Thread starter Thread starter Nikitin
    Salt Solubility
A saturated solution of a salt at constant temperature and pressure maintains a constant concentration of dissolved salt, regardless of the amount of solid salt added. This is due to the definition of saturation, which indicates that the solution has reached its maximum capacity for dissolving that particular salt. As more solid salt is introduced, it does not increase the concentration of dissolved ions in the solution.
  • Understanding of saturated solutions
  • Knowledge of solubility principles
  • Familiarity with temperature and pressure effects on solubility
  • Basic chemistry concepts regarding dissolution
  • Research the concept of solubility product constant (Ksp)
  • Explore the effects of temperature on solubility
  • Learn about the role of pressure in gas solubility
  • Investigate common salts and their solubility limits
Chemistry students, educators, laboratory technicians, and anyone interested in understanding the principles of solubility and solution chemistry.
Nikitin
Hey. Will a saturated solution of a salt at a constant temperature and pressure have a constant amount of dissolved salt even as you add more salt? Let us pretend that acid-base or metal-complex reactions don't happen.
Chemistry news on Phys.org
Saturated means - no more can dissolve, so yes, concentration of dissolved salt doesn't change when you add more solid.
  • · Replies 23 ·
