Lyapunov Function: Show 0 is Stable
  • Context: Graduate
  • Thread starter Thread starter rjcarril
    Function Lyapunov
The discussion centers on demonstrating the asymptotic stability of the equilibrium point at 0 using a Lyapunov function, specifically V(x) = \|x\|^2. It is established that if f(0) = 0 and the Jacobian Df(0) has eigenvalues with negative real parts, then \dot V, calculated as 2x \cdot (Df(0) \cdot x) + O(\|x\|^3), will be negative in a neighborhood of 0. This negative sign of \dot V confirms that 0 is asymptotically stable, provided that \dot V < 0 holds true in that neighborhood.
  • Understanding of Lyapunov stability theory
  • Familiarity with eigenvalues and eigenvectors
  • Knowledge of gradient and directional derivatives
  • Basic concepts of dynamical systems
  • Study the construction of Lyapunov functions in nonlinear systems
  • Learn about the implications of eigenvalues in stability analysis
  • Explore the concept of strict Lyapunov functions
  • Investigate the role of higher-order terms in stability proofs
Mathematicians, control theorists, and engineers interested in stability analysis of dynamical systems, particularly those working with nonlinear systems and Lyapunov methods.
rjcarril
Assume that f(0) = 0 and Df(0) has eigenvalues with negative real parts. Con-
struct a Lyapunov function to show that 0 is asymptotically stable.
I know it is a strict lyapunov function, but i cannot figure out how to solve it for the general case.
Consider [itex]V(x) = \|x\|^2 = x \cdot x[/itex]. Then [itex]\nabla V = 2x[/itex] and
[tex] \dot V = \nabla V \cdot \dot x = \nabla V \cdot f(x) = <br /> 2x \cdot (Df(0) \cdot x) + O(\|x\|^3).[/tex]
What does the condition on the eigenvalues of Df(0) imply about the sign of [itex]x \cdot (Df(0) \cdot x)[/itex]? What does that imply about [itex]\dot V[/itex] for [itex]\|x\|[/itex] sufficiently small?
Can you prove that if [itex]\dot V < 0[/itex] on a neighbourhood of 0 then 0 is asymptotically stable?
  • · Replies 0 ·
