pervect said:
If you're falling straight in, and looking straight outwards, and your fall started at infinity with zero velocity, I believe you'll wind up with a net redshift. But I couldn't find the detailed calculation.
Yes, I have done, but never posted, the calculation in Painleve-Gullstrand coordinates.
If observer A, who hovers at great distance from the black hole, radially emits light of wavelength [itex]\lambda[/itex], then observer C, who falls from rest freely and radially from A, receives light that has wavelength
[tex]\lambda' = \lambda \left( 1+\sqrt{\frac{2M}{R}}\right).[/tex]
The event horizon is at [itex]R = 2M[/itex], and the formula is valid for all [itex]R[/itex], i.e., for [itex]0 < R < \infty[/itex]. In particular, it is valid outside, at, and inside the event horizon.
Lino said:
Pervect, Would the net effect be driven by your infalling acceleration at the point were you carry out the observation, or would it always be redshifted?
According to the formula posted above, there is always a redshift.
Suppose observer that A hovers at a great distance from a black hole, and that observer B hovers very close to the event horizon. The light that B receives from A is tremendously blueshifted. Now suppose that observer C falls freely from a great distance. C whizzes by B with great speed, and, just past B, light sent from B to C is tremendously Doppler reshifted. What about light from A to C? The gravitation blueshift from A to B is less that the Doppler redshift from B to C. As C crosses the event horizon, C sees light from distant stars redshifted, not blueshifted.
The argument in the previous paragraph only works for B placed anywhere outside the event horizon, but the formula is valid every.
Chronos said:
If you are in free fall, the external universe will be progressively redshifted as you approach the EH. By the time you reach the EH, the external universe will appear infinitely redshifted [just like you will appear infinitely redshifted to a stationary external observer].
No, at the event horizon, light is redshifted by a factyot of 2.
