Is dτ Invariant Under Transformations Beyond Lorentz in Special Relativity?
  • Context: Graduate
  • Thread starter Thread starter friend
    Invariance Sr
The discussion revolves around the invariance of the infinitesimal line segment, dτ, in special relativity and whether this invariance extends beyond Lorentz transformations. Participants explore the implications of dτ being invariant under various coordinate transformations and seek to understand the foundational principles that lead to the metric of special relativity.
  • Some participants propose that the metric of special relativity can be derived from the requirement that dτ is invariant in space and time.
  • Others argue that dτ is invariant only under Lorentz transformations, questioning if other transformations could also preserve this invariance.
  • A participant suggests that the invariance of dτ might be a driving force behind the necessity of Lorentz transformations.
  • There is a discussion about the implications of dτ being a direct observable, which must retain the same value across all coordinate systems.
  • One participant expresses a desire to derive the special relativity metric without starting from the observed speed of light, proposing the use of the Dirac delta function as a potential foundational principle.
  • Questions are raised about the meaning and implications of integrating functions involving dτ and how these relate to coordinate invariance.
Participants express differing views on the invariance of dτ under transformations beyond Lorentz transformations. While some assert that it must always be invariant, others question the conditions under which this holds true. The discussion remains unresolved regarding the foundational principles that lead to the metric of special relativity.
Participants acknowledge that the discussion involves complex concepts related to the nature of time, space, and the mathematical framework of special relativity, with unresolved assumptions about the role of coordinate systems and the implications of direct observables.
friend
Can the metric of special relativity be derived from requiring the infinitesimal line segment, dτ, to be invariant in space and time? If we parameterize a line segment by the variable τ marked off along the line (that exists in space and time dimensions) is the length in τ of that line segment only invariant with respect to the Lorentz transformations? Or are there other coordinate Xformations for which dτ would also be invariant? Thank you.
Mentz114 said:
Thank you. I'm trying to keep up with that thread. There's some interesting stuff there. I tried asking some questions there. But they seem to be focused on their own goals in that thread. So I'd like to post my questions here to see if I can generate interest and get comments here without cluttering up someone else's thread.
I'm given to understand that
2=dt2-dx2 = dt'2-dx'2
when (t',x') are the Lorentz transformation of (t,x).
Perhaps it's instructive to consider in what circumstances dτ should want to be considered invariant wrt to coordinate changes. Maybe those requirements are the driving force behind the necessity of the Lorentz transformations.
For example, the most obvious use of dτ is in the calculation of the line integral,
[tex]\int_{{\tau _0}}^\tau {d\tau '} = \tau - {\tau _0}[/tex]
which is the length of a line measured in terms of segments marked off along the length of the line. Then, of course, we can always place this line in an arbitrarily oriented coordinate system and express τ in term of those coordinates.
So the question are: 1) when do we want to use the coordinates (t,x), and 2) when would we want τ-τ0 to be invariant wrt to those coordinates?
As far as 1) goes, usually, we specify a curve in space by parameterizing the space coordinates with an arbitrary variable, call it "t". But since the x and t coordinates are arbitrarily assigned, the length of the curve can depend on the (t,x) coordinates. But if you specify that the length of the curve is invariant, then this requires the Lorentz transformations between coordinate systems.
But for 2) what should require the length of the curve to be invariant? Perhaps if we have a more fundamental requirement like
[tex]\int_{{\tau _0}}^\tau {f(\tau - {\tau _0})d\tau } = a[/tex]
this will require the length of τ-τ0 to be invariant wrt to coordinate changes in (t,x). For example, maybe [itex]{f(\tau - {\tau _0})}[/itex] might be a probability distribution along a path so that its integral along the path must be 1 in any coordinate system.
Did I get this all right? I would appreciate comments. Thank you.
Before I attempt to answer your questions, I should point out that the LT is the only known transformation that retains the causal structure of SR. Time-like, null and spacelike intervals retain this property under LT. Also, crucially, identifying the proper interval as the time recorded on a clock traveling on the curve in question eliminates all clock paradoxes (time-bomb paradoxes) because the clock times are invariant. I know you're most probably aware of this.
It seems to me that the answer to 2) is 'always - if SR is to be consistent'. I don't understand the first question. We have to use some coordinates or other in this methodology.
[tex] \int_{{\tau _0}}^\tau {f(\tau - {\tau _0})d\tau } = a[/tex]
Right now I can't see any meaning in this. I'll have to think about it.
Yes.
As Mentz114 said, the answer to this is "always". The reason is that [itex]d\tau[/itex] is a direct observable; it corresponds to the elapsed time on a clock following the given worldline for an infinitesimal segment. Direct observables must have the same value in all coordinate systems, so their values have to be invariant under coordinate changes.
Exactly; that's the main point of that other thread Mentz114 referenced.
It's also the time elapsed on a clock following the given worldline from [itex]\tau_0[/itex] to [itex]\tau[/itex]. So as I said above, it's a direct observable.
Yes, and the value of [itex]\tau[/itex] must be the same regardless of which coordinates you express it in.
As opposed to what other coordinates?
Always.
Actually, [itex]\tau[/itex] itself can be used to parameterize the worldline. The coordinates (t, x) are then functions of the parameter [itex]\tau[/itex].
No, they're not, because this...
...is false. The length of the curve is an observable. See above.
Yes.
Because it's a direct observable. See above.
I appreciate your comments. I can see that you are knowledgeable in SR. However, I don't think you understand what I'm trying to do here. I'm trying to explain where the SR metric, with its speed of light, comes from to begin with. So I'm trying to avoid starting with the observed speed of light as in the usual development of SR. And I'm trying to find principles that would give rise to the metric of SR, with its implied speed of light.
So my thinking is that since the Dirac delta function is used in the development of QM, it might also be used to develop SR. And here's how I figure. Since we have
[tex]\int_{ - \infty }^{ + \infty } {\delta (\tau ' - {\tau _0})d\tau '} = 1[/tex]
we can embed this line integral in a background spacetime (t,x), where [itex]\tau[/itex] then becomes a function of the coordinates (t,x). And then it seems that the requirement that this integral remain constant wrt changes in coordinate system requires the coordinate transformations to be Lorentzian to keep [itex]{\tau - {\tau _0}}[/itex] invariant. Does this sound right to you?
[tex]\int_{ - \infty }^{ + \infty } {\delta (\tau - {\tau _0})d\tau '} = 1[/tex]
My first take on this is that there's nothing wrong with your argument in the second paragraph, but it doesn't tell us anything we didn't know. Incidentally, is the prime on the differential a typo or significant ?
The speed of light is in the metric itself because for a null curve 0 = dt2-dx2 implies (dx/dt)2=1.
This still doesn't completely clear up what you're trying to do, at least not for me. When you say "the SR metric", it seems to me that you really mean "the Lorentz transformation", since that's what preserves the spacetime interval. So it seems to me that the question you're really trying to ask is "where does the Lorentz transformation come from?" and find an answer that doesn't depend on any assumptions about the speed of light.
If the latter is really your question, the best explanations I've seen that don't depend on any assumptions about the speed of light, start from the assumptions of translation and rotation invariance. That is enough to narrow down the possibilities to either the Lorentz transformation or the Galilei transformation, which is just the limit of the Lorentz transformation as c -> infinity. More precisely, translation and rotation invariance are enough to show that there must be some "invariant speed" c that appears in coordinate transformations, but which may be infinite (Galilei transformation) or finite (Lorentz transformation). The only way to choose between these two options is by experiments like the Michelson-Morley experiment, which show that the invariant speed is finite.
friend said:
And then it seems that the requirement that this integral remain constant wrt changes in coordinate system requires the coordinate transformations to be Lorentzian to keep invariant. Does this sound right to you?
Not really. The delta function [itex]\delta ( \tau - \tau_0 )[/itex] is zero unless [itex]\tau = \tau_0[/itex]. I don't see what that's supposed to mean physically; it looks like you're saying that no proper time elapses at all except at the single event [itex]\tau_0[/itex], where *all* of the proper time on the entire worldline of the object elapses. That doesn't seem reasonable to me.
Ideally, I don't want to start with any assumptions about what kind of transformations apply. I'd like the transformation to be derived from some more fundamental requirement not based on any measurement of anything physical. I have reason to believe that the Dirac delta function is a mathematical representation of causality. At least in linear systems a system is considered causal depending on how it responds to an impulse = dirac delta. So if there is some logic for starting with the integral of the Dirac delta, then perhaps the constant speed of light and the Lorentz transformations can be derived from that logic.
I'm not entirely confident that I want to start with the Dirac delta function. For if we change the coordinate on the curve to [itex]\tau ' = a\tau[/itex] , then [itex]d\tau ' = ad\tau[/itex] , and [itex]\tau = \tau '/a[/itex] , and [itex]d\tau = d\tau '/a[/itex] . Then we have [itex]\tau - {\tau _0} = \tau '/a - \tau {'_0}/a = (\tau ' - \tau {'_0})/a[/itex] and [itex]\delta (\tau - {\tau _0}) = \delta ((\tau ' - \tau {'_0})/a)[/itex] . And this gives us by the scaling property of the Dirac delta,
[tex]\int_{ - \infty }^{ + \infty } {\delta (\tau - {\tau _0})d\tau } = \int_{ - \infty }^{ + \infty } {\delta ((\tau ' - \tau {'_0})/a)\frac{{d\tau }}{a}} = \int_{ - \infty }^{ + \infty } {a \cdot \delta (\tau ' - \tau {'_0})\frac{{d\tau '}}{a}} = \int_{ - \infty }^{ + \infty } {\delta (\tau ' - \tau {'_0})d\tau '} = 1[/tex]
So it seems this integral is insensitive to changes in the [itex]\tau[/itex] coordinate. Does this mean that ANY changes in the backgound (t,x) could change the [itex]\tau[/itex] coordinate in arbitrary ways that still results in the integral being 1? In other words, the integral no longer depends on the [itex]\tau - {\tau _0}[/itex] not changing. Wouldn't that mean that this integral has no power to restrict the background transformations to the Lorentz transformations? Or does this scaling property allow only changes in [itex]\tau[/itex] by a constant factor? Can I still get the Lorentz Xformation from this?
Perhaps it would be better to integrate a different function other than the Dirac delta. Then I'd not be dealing with the scaling property and the integral could restrict the background transformation of (t,x) to the Lorentz type.
The assumptions of translation and rotation invariance aren't assumptions about what kinds of transformations apply. They're very general assumptions about the physics, that happen to have as a consequence the restriction on possible transformations that I gave.
I'm not sure why translation and rotation invariance wouldn't count as "fundamental requirements".
This seems like a strange thing to want. In order to test whether *any* fundamental assumption actually holds, you're going to have to make physical measurements and compare them with what you would expect to see if the assumption were true.
That's not the same as the delta function itself being a representation of causality. The representation of causality is in the *response* function, not the function describing the initial impulse.
Why are you starting with integrals in the first place? If you're looking for fundamental requirements, it seems to me that you would want to start with something local, i.e., to only look at physical quantities and their derivatives (or infinitesimals) at a single point. The integral representation of physics over a finite length or in a finite region is built up from the local representation; it's not fundamental in itself.
My question is: what logical necessity could there possibly be for the invariance of [itex]d\tau[/itex] that could give rise to the Lorentz metric with its constant speed of light. So in effect I'm trying to explain the LT and c. I don't think an explanation of such can start by measurements of c, that would be a circuilar argument. Yes, of course, whatever theory one derives must be confirmed by experiment. But I don't think experiment is an explanation for the experiment. That would be finding some math that fits the data without an explanation for the data or the math, IMO. If you are not comfortable with this approach to the problem, you don't have to contribute.
Why the integral? As I said in post 3, the most obvious use of dτ is in the calculation of the line integral,
∫dτ′=τ−τ0
And when would τ−τ0 be invariant. Well you could have τ−τ0=constant. But then you ask why. So you notice that this is just another way of saying f(τ−τ0)= constant. And I suppose that this could always be put in the form
∫g(τ'−τ0)dτ′=constant
And one thing to consider is the integral of the Dirac delta equal to one, always, in any coordinate system, right?
Because [itex]d\tau[/itex] represents a direct physical observable, the time elapsed on a clock over a very small portion of its worldline. It seems reasonable to want your mathematical model of physics to represent direct physical observables by quantities that are invariant under coordinate transformations. Whether that counts as "logical necessity" seems to me to be beside the point; every physical theory has to be based on some assumptions that can't be proved, but just have to be taken as given.
That's where translation and rotation invariance comes in; and I also should have included invariance under boosts, i.e., under changes of inertial frame, because of the principle of relativity: physics should look the same to two observers who are inertial and are moving at a constant velocity relative to each other.
You don't have to start with measurements of c if you start with translation, rotation, and boost invariance; those requirements are enough to narrow down the possible transformations to Lorentz or Galilei transformations, as I said before. But you do have to know about measurements of c if you want to determine whether Lorentz or Galilei transformations are the right ones. I don't know of any other way to make that determination.
Part of the problem here may be the issue of what counts as an "explanation". If I say that physics has to be translation, rotation, and boost invariant, does that count as an explanation of why only Galilei or Lorentz transformations are allowed? If I need experiments to tell me that the invariant speed is finite instead of infinite, does that count as an explanation of why Lorentz transformations, not Galilei transformations, are the right ones to use? To me these are questions about words, not about physics.
Of course you could continue to ask questions, like "why does the invariant speed have to be finite rather than infinite?". AFAIK nobody has a good answer to that question, other than "that's what we find experimentally". Does that mean we don't have an explanation? Again, that seems to me to be a question about words, not about physics.
The LT (together with the Galilean transformation when not including the second postulate of SR) as commented by Peter Donis is based first of all on the reasonable assumption of isotropy and homogeneity, geometrically this is a feature of constant sectional curvature spaces, this assumption introduces the choice of a metric and since the motion that is dealt with in this case is inertial motion the logical constant curvature metric to choose (also remember this is 1905 for Einstein's SR and 1907 for Minkowski coming up with the natural space for SR, Einstein hadn't introduced the idea of curvature in physics yet) was the flat one, this leads to the linearity of both Galilean and Lorentz transformations.
The invariance of a finite c was Einstein second postulate of SR, there is no logical necessity for a postulate, it just happens to be backed up by experiments.
Also invariance of dτ is not equal to SR since it is shared by GR for instance.
EDIT: I see Peter has already answered, sorry about the overlapping.
OK, so what I'm beginning to understand is that the invariance of [itex]d\tau[/itex] only implies the flat metric locally. However, does this mean that the invariance of [itex]\int_{{\tau _0}}^\tau {d\tau ' = } \tau - {\tau _0}[/itex] would specify a more global flat space, with a Lorentzian or Galilean transformation? If c is not infinite, then the background metric is Lorentzian and the same along the trajectory, is this right?
Perhaps the only reason that there must be a finite c is because if it were infinite, then everything would happen all at once and there would be no distinction between cause and effect. How's that sound? It's a little more basic than measuring c.
Yes.
Yes. It also assumes that the curve parametrized by [itex]\tau[/itex] is a straight line in that global flat spacetime (I use that word in preference to "space" since time is one of the dimensions in this "space".)
In a flat spacetime, yes.
I'm not sure that works, because Newtonian physics has an "infinite c", and everything doesn't happen all at once in Newtonian physics.
Right, what actually happens in Newtonian physics rather than "happenning all at once" which would imply a block-like interpretation is that there is no relativity of simultaneity. Time and space are not related in the same way they are in SR.
If c were infinite, you could cause and emission over there by forcing an absorbsion of a photon over here. My argument is that it is not logical for nature to ever be ambiguous about cause and effect. And one way to do this (if not the only way) is to ensure that c is not infinite. Some people even try to derive the Lorentzian metric from the requirement of causality alone. Although I think they are presupposing causality and not arguing for its necessity to begin with.
EDIT: To continue with these thoughts... Suppose a particle could travel with infinite speed, it would be impossible to say where the particle was at that instant. It could be anywhere from the edge of the universe to your present location. It would turn a point particle at one instant into an 13.75ly line an infinitesimal instant later, which would be a totally different thing than a particle. Further, there would be no frame of reference in which the particle is at rest. Would this violate the differential structure of the universe? Doesn't causality require a different position for each value of time?
I guess my question is whether diffeomorphism invariance requires the choice of Lorentz transformations above Galileans transformations. Is diffeomorphism invariance between coordinate transformations a more basic necessity to physics than measuring the speed of light? I mean, if the laws of physics necessarily require diffeomorphisms between frames of reference, does that necessarily exclude the infinite speeds used in the Galilean transformations? Can there be a diffeomorphism between two frames of reference when one of them has and infinite speed? And if not, does that make diffeomorphism invariance more basic than the speed of light? Thanks.
This is probably an easy question for some:
I've seen where if we start with the Lorentz transforms, we can show that dτ and even τ-τ0 is not changed. But I wonder if we can go the other way. If we start with the requirement that dτ or τ-τ0 should not vary, can we then derive the Lorentz transformations? I'd appreciate any help on this. Thanks.
I think I found a paper that does what I'm asking. It seems to derive the Lorentz transformations from the properties of spacetime alone. I'd appreciate comments on this paper, 7 pages, relatively easy math. Thank you.
One more derivation of the Lorentz transformation
This is the sort of thing I was referring to in posts #8 and #12, when I said that translation, rotation, and boost invariance are enough to narrow down the possibilities to Lorentz or Galilei transformations. I think there have been other published papers taking a similar approach, but I haven't been able to find links.
Correct me if I'm wrong. But I think he is using the causality condition to choose between Lorentz and Galilei transformations. (see Hypothesis 4: causality, page 276, second to last page)
He explicitly says that his causality requirement (that the sign of the time interval be unchanged by a transformation) is satisfied by Galilei transformations for all time intervals; so he can't be using that requirement to rule out Galilei transformations in favor of Lorentz transformations. He only uses causality to rule out a third possibility, which he gives as case 9i) on page 275. I don't know if this third possibility has ever been given a name.
As far as I can see, this paper doesn't rule out Galilei transformations, and doesn't claim to. The only hint it gives as to why Lorentz transformations might be preferred is that it several times refers to Galilei transformations as the "singular limit" of Lorentz transformations ("singular" presumably refers to the fact that Galilei transformations are what you get when you take the limit of Lorentz transformations as c -> infinity). But the paper doesn't elaborate on that.
Interesting paper. The four hypotheses do seem the minimum to end up with a group of transformations that preserve causality. The bad news is that the group is non-commutative, so making two boosts in different directions becomes a problem.
Did you see the 'note added ...'. Apparently this was all known in the 1920's.
I still have questions about his math. Is this a good thread to ask such questions? Or should I start a new thread to discuss this paper specifically?
Why is that a problem? Boosts in different directions don't commute, so in deriving the full group of (linear) inertial motion transformations for 1+3D spacetime, one must take account of ordinary rotations...
The group law assumption in all these types of derivations boils down to the hypothesis that boosts along a fixed direction should form a 1-parameter Lie group.
Maybe some of it was known even earlier. The standard references are Ignatowsky and also Frank+Rothe (though I've been unable to source them, and they appear to be in German anyway -- I haven't found a translation).
Well, it's your thread so it seems reasonable that you get to choose what's on-topic...
BTW, such derivations become a little clearer (imho) if the step involving the group composition law is split into two steps. The result that a v-independent constant emerges can be found by using the fact that elements of a 1-parameter Lie group must commute. After establishing this, the full composition law can be used more easily to derive the velocity addition rule.
It does not. Diffeomorphisms do not even involve a metric.
There are no inertial frames such that the speed of one of them relative to the other is infinite.
For example, he writes on the bottom left of page 272 of,
One more derivation of the Lorentz transformation,
"..., we consider (3) for given (x,t) and (x',t') as a set of two equations in n unknowns {a1,a2,...,an}. It is clear that, if n≥2, these equations will, in general, have solutions; an interval between two physical events might then have arbitrary coordinates... On the other hand if n=0, there would be no other inertial transformations than space and time translations, and no proper theory of relativity. From this argument we may conclude that n=1,..."
I want to make sure I understand him here. Is he saying that if you have two equations in more than two unknowns, then you have an underdetermined set of equations, with not enough equations to solve for the unknows? But I thought for n=2, there is two equations in two unknowns, so that you do have enough info to solve for the two unknown a's. What am I missing?
Also, he seems to conclude n=1 on the basis of a physical argument ("no proper theory of relativity") which I thought he was trying to avoid. Thanks for any help in advance.
[Original reply replaced by...]
I think this part of his argument is questionable, since it ignores uniform dilations of the form ##(t',x') = (e^\alpha x, e^\alpha t)##, where ##\alpha## is independent of ##x## and ##t##. Including such dilations would lead to 2-parameter transformations. He dispenses with dilations implicitly a bit later in the paragraph after eq(9) where he describes the case ##K(a)=0## as pathological, and in the related footnote 10 he mentions the "static group" or "Carroll" group. So he's implicitly assuming a common scale in both frames.
Another way of looking at this is that for the case ##v=0##, the old and new frames are one and the same, apart from a possible scale difference in their respective units of time and length -- which are promptly assumed to be standardized uniformly when the origins coincide.
  • · Replies 22 ·
  • · Replies 101 ·
  • · Replies 32 ·
  • · Replies 29 ·
  • · Replies 144 ·
12K
