Dc off-set Analysis - Maatlab code
The discussion focuses on performing DC-offset analysis using MATLAB. The user implemented a filter with the code snippet `a = [1 , -0.98]; b = [1,-1]; y = filtfilt(b,a,x);` to process a raw signal. However, the user seeks guidance on achieving a specific final graphical output that resembles a desired result. The request emphasizes the need for precise code to replicate the expected outcome.
  • Familiarity with MATLAB programming and syntax
  • Understanding of digital signal processing concepts
  • Knowledge of filter design and implementation in MATLAB
  • Experience with graphical data representation in MATLAB
  • Research MATLAB's `filtfilt` function for zero-phase filtering techniques
  • Explore MATLAB's filter design functions to customize filter parameters
  • Learn about signal preprocessing techniques for DC-offset removal
  • Investigate MATLAB plotting functions to enhance graphical output
This discussion is beneficial for MATLAB users, signal processing engineers, and researchers looking to analyze and visualize raw signal data effectively.
Hzaqa
Hi,
I am trying to use Matlab to analyse this raw signal by introducing Dc-offset analysis:
I used the following code :
figure
plot(y)
And the result :
But, I am trying to get a final result similar to the last graph,
Can you please tell methe exact code to achieve this:
Thank you very much
Up
Up
UP
11K
