Need opinion on a heat sink (concept)
The discussion revolves around a proposed design for a heat sink that incorporates a fan coupled with a motor to supply cool air. Participants are evaluating the effectiveness of this design, particularly in terms of contact area and cooling efficiency, and whether similar mechanisms are already in use.
  • One participant suggests that the low contact area between the heat sink and the component being cooled is a significant issue, noting that most effective designs have a solid base to maximize heat transfer.
  • Another participant questions whether reducing the fan size and increasing the contact area would improve cooling rates, indicating a potential trade-off in design.
  • Participants discuss the importance of the material being cooled, with one suggesting that the interface between the heat sink and the heat source is crucial for effective cooling.
  • A suggestion is made to eliminate the hole in the heat sink where the fan is located to improve contact with the hot surface, emphasizing the need for a solid base.
  • Concerns are raised about the potential disturbance caused by outward airflow from the fan, which could affect its performance.
  • Visual examples are shared to illustrate effective heat sink designs, reinforcing the idea that full surface contact is necessary for optimal cooling.
Participants express differing views on the design's effectiveness, particularly regarding the contact area and the role of the fan. There is no consensus on the best approach to improve the cooling mechanism.
Participants note the importance of the specific application and materials involved, which may affect the performance of the proposed heat sink design. The discussion highlights various assumptions about airflow dynamics and thermal transfer that remain unresolved.
silent_hunter
Hello, I want to share a very simple concept with you guys. Last night I randomly modeled a heat sink [the fan is coupled with a motor,cool air will be supplied separately(details are in the picture)], now please give your opinion on it. Will this system work? I don't know if this type of mechanism is already in use or not.
thank you.:smile:
The only problem I see is that the contact area of your heatsink with whatever it is supposed to be cooling is very low. This is why most commercial HSFs (heatsink + fan) have a solid base. The more contact area you have to carry heat away from the device and into the fins/pins, the better.
This design would probably not work for a CPU since most of the heat is generated right in the center, where you have no contact at all, and the integrated heat spreader is a simple thin aluminum plate.
Some older video cards do have a design like yours, with the fan embedded within the heatsink, but they too still retain a solid base below the fan.
thanks for your reply.
So according to you may the cooling rate be improved if I reduce the size of the fan and increase contact area?
What are you trying to cool? Is it a solid square object directly below the fan? What is it made of?
lets say its a hub sink made of Aluminium,I mean it cools multiple heat source perhaps by liquid cooling or like this one below (can be used for other purposes too)
(taken from www.hothardware.com/articleimages/Item1128/small_Asetek_LCLC_3Dmodel.jpg)
I ask because it matters how the heatsink interfaces with whatever it's primarily cooling, be that a hot surface like a CPU heat spreader, or water block, or whatever.
Not knowing that, my suggestion is not to shrink the fan (though that would help) but to put a solid base below the fan -- get rid of the 'hole' the fan blows through, presumably onto something hot that needs cooled, and get that hot thing in touch with the metal of your heatsink.
Like so:
http://www.ikbensnel.nl/Pictures/heatsink.jpg
You can cut a hole in the fins to put the fan in, but that's reducing the surface area that the air can move over, so you need to compensate with a higher CFM fan. That may not even be enough depending on the thermal coefficient of whatever you're building the HSF out of. Best to just slap the fan on top, in a shroud, like everyone else does (for good reason) ;)
justsomeguy said:
got it ,thanks.
one thing, Can outward flow of cool air below the fan(3rd pic of my 1st post) create disturbance for the fan(since air forces blades on the opposite direction of its rotation) ?
This is similar to what you're proposing, maybe it makes it more clear. Whatever you're trying to cool needs to have it's full surface in contact with the heat sink material. You also want to block axial flow through the fan to ensure all the air is pushed around heatsink vanes and not just into some material it can't effectively cool.
Image is from an old low-power graphics card HSF. The other two heatsinks are passive coolers for the DRAM.
A clearer example:
http://www.p-wholesale.com/upimg/5/115a2/universal-vga-heat-sink-473.jpg
justsomeguy said:
got it ,thanks.
  • · Replies 21 ·
