Efficiently calculating the magnitude of gravitational force
The discussion focuses on calculating the gravitational force between a uniform thin spherical shell of mass M and a particle of mass m, as presented in Kolenkow and Kleppner's Classical Mechanics. The method involves dividing the shell into narrow rings and using calculus to integrate the gravitational effects from these rings. The participants emphasize the importance of symmetry in simplifying the calculations, suggesting that while Gauß' law can be applied, the integral approach remains the most straightforward method for this problem.
  • Understanding of gravitational force and Newton's law of gravitation
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of symmetry principles in physics
  • Basic concepts of mass distribution in spherical coordinates
  • Study the application of Gauß' law in gravitational fields
  • Learn advanced integration techniques for physics problems
  • Explore the concept of mass distribution in spherical shells
  • Review symmetry in gravitational force calculations
Physics students, educators, and anyone interested in gravitational force calculations and the application of calculus in classical mechanics.
Richard Nash
I am reading Kolenkow and Kleppner's Classical Mechanics and they have tried to calculate the gravitational force between a uniform thin spherical shell of mass [itex]M[/itex] and a particle of mass [itex]m[/itex] located at a distance [itex]r[/itex] from the center.
The shell has been divided into narrow rings.[itex]R[/itex] has been assumed to be the radius of the shell with thickness [itex]t[/itex] ([itex]t<<R[/itex]). The ring at angle [itex]\theta[/itex] which subtends angle [itex]d\theta[/itex] has circumference [itex]2\pi R\sin\theta[/itex].The volume is $$dV=2\pi R^2t\sin \theta d\theta$$ and its mass is $$pdV=2\pi R^2t\rho\sin\theta d\theta$$
If [itex]\alpha[/itex] be the angle between the force vector and the line of centers, [itex]dF=\frac{Gm\rho dV}{r'^2}\cos\alpha[/itex] where [itex]r'[/itex] is the distance of each part of the ring from [itex]m[/itex].
Next, an integration has been carried out using $$\cos\alpha=\frac{r-R\cos\theta}{r'}$$ and $$r'=\sqrt{r'^2+R^2-2\pi R\cos\theta}$$
Question: I would like to avoid these calculations and I was wondering if there exists a better solution.
Science news on Phys.org
You can use Gauß' law and symmetry. But if you want to calculate it via an integral, I don't think there is an easier way.
Welcome to PF!
You certainly need to use calculus. When one does this kind of calculus problem one has to use as much symmetry as possible. It seems that is achieved by dividing the sphere into rings perpendicular to the axis through the centre of the sphere and the point mass, calculating the gravity from a ring and integrating from one end to the other. If that is what they are doing, that is as simple as it gets.
AM
  • · Replies 17 ·
  • · Replies 29 ·
  • · Replies 16 ·
