Understanding the Corpus Callosum: Function, Size, and Structure
  • Thread starter Thread starter biferi
The discussion centers on the corpus callosum, specifically its function, size, and structure. Participants explore its classification as the largest white matter structure in the brain, comparing its dimensions and characteristics to other brain structures.
  • Some participants note that the corpus callosum is approximately 4 inches long and consists of a band of fibers connecting the left and right hemispheres of the brain.
  • There is a question regarding the terminology of "largest," with some suggesting it may refer to volume rather than length, while others express uncertainty about comparisons with structures like the corona radiata.
  • One participant argues that the definition of "largest" should consider cross-sectional area and the number of fibers, rather than just linear dimensions.
  • Another participant emphasizes that terms like "large" or "small" require context for meaningful comparison.
Participants do not reach a consensus on what constitutes the "largest" white matter structure, with multiple competing views on the definitions and comparisons involved.
Participants express uncertainty regarding the definitions of size and volume in the context of brain structures, and there are unresolved questions about how different dimensions affect the classification of the corpus callosum.
biferi
I know the Corpus Callosum is in the Middle of the Brain and is about 4 inch long.
It is a Band of Fibers that connect the Left and Right side of the Brain.
And I know that the Fibers Brantch out is this why they say it is the Largest white matter in the Brain because it Brantches out?
I ask because it is 4 inch Long and this is not that big so I thought it was because it Brantches out that makes it big.
Biology news on Phys.org
Could you please provide a reference?
It's the largest of the interhemispheric commisures.
This is a link to a youtube video
It says it is 4 inches long and is a Band of Fibers.
I wasn't asking about the size. I was asking about the statement that it's the "largest". I know it's the largest of the interhemispheric commisures, but it's not immediately clear to me that the corona radiata isn't larger. Perhaps the corona radiata is considered to consist of several tracts, so the corpus callosum might be the largest white matter tract, but I'm not sure.
I think we look at largest in the sense of the "most stuff in it (volume)", rather than length of some dimension, when we refer to largest in this context. So, I agree with atyy.
I can agree that 4 inches in length is large, but I don't know where that gets me.
If you have a two foot long steel .5 inch diameter rod, and a steel ingot that is a 1 foot cube, which one is larger? The ingot.
So the corpus callosum is a 4 inch Band of Fibers and this to me seems Short in length.
But because it has Thousands of Tracks or Fibers this is why they say it is Larg right?
In signal conduction, there are two important dimensions: the cross-sectional area and the length.
The resistance of a classical resistor goes up with length and down with cross-sectional area, so if you're talking about positive benefits, you usually talk about the cross-sectional area itself.
In biological systems, length doesn't attenuate signal because of the nature of all-or-nothing firing (of course, it does attenuate passive currents). But it still takes more time to travel longer lengths, so lengths is still a "negative" as far as signal conduction is concerned.
So yeah, I think "large" refers to the beneficial dimension, the cross-sectional area (which increases with the number of fibers.
In the OP you asked about "largest", which is at least comparative. But here you ask about "large". In science "large" or "small" are meaningless without further specification. You have to say large or small compared to what.
  • · Replies 41 ·
12K
  • · Replies 42 ·
  • · Replies 38 ·
12K
