PH<pKa means acidic form, but why?
  • Thread starter Thread starter shrew
    Form Means
The discussion clarifies the relationship between pH, pKa, and the forms of compounds, specifically focusing on ammonia (NH3) and its conjugate base (NH2-). It establishes that when pH is less than pKa, the compound exists in its acidic form, while pH greater than pKa indicates a basic form. The conversation highlights that strong bases, such as NH2-, will convert to their conjugate acids (NH3) upon reacting with other substances, thereby demonstrating their role in proton removal. This understanding solidifies the concept that even strong bases can predominantly exist as their conjugate acids in solution.
  • Understanding of acid-base chemistry principles
  • Familiarity with pH and pKa concepts
  • Knowledge of conjugate acids and bases
  • Basic chemical reaction mechanisms
  • Study the concept of conjugate acid-base pairs in detail
  • Learn about the pKa values of various compounds
  • Explore the behavior of strong bases in different solvents
  • Investigate the role of proton transfer in acid-base reactions
Chemistry students, educators, and professionals in fields related to biochemistry and chemical engineering who seek to deepen their understanding of acid-base behavior and the implications of pH and pKa in chemical reactions.
shrew
I've memorized the following:
pH<pka, then acidic form
pH>pka, then basic form
And I'm guessing that pH=pka means neutral.
However, my instincts tell me it would be the opposite. Take NH3, ammonia, with a pKa of around 40. And then there's NH2-, which from a google search, has an incredibly high pKa. These are both basic.
So what the above rules state, is that if you added an amount of one of the above bases into a solution with pH=0, pH=7, or pH=14... in all cases the above bases would be in their acid forms?
So they're bases yet they're going to be in their acidic forms... if practically every solvent you add them to will turn them into acids, how can they be thought of as bases?
Chemistry news on Phys.org
Compounds that are strong bases are considered strong bases because they will remove protons from other substances. For example, consider the reaction of the base NH2- with a compound like methanol:
NH2- + CH3OH --> NH3 + CH3O-
In reacting with methanol the base NH2- is converted to its conjugate acid NH3. Therefore, a base being converted to its conjugate acid means that the base has done its job: it has removed a proton from another substance and it will comfortably hold on to that proton and not let go of it. Hence, most strong bases will almost always exist as their conjugate acids once you mix that base with any other substance. Similarly, most strong acids will almost always exist as their conjugate bases once you mix the acid with any other substance.
Note that even though the conjugate acid of a strong base may be referred to as an acid, it will not be a very strong acid. These conjugate acids will be very unlikely to donate their protons to other substances. For example, NH3 is a very weak acid and it takes a lot to remove the proton from NH3 to reform NH2-.
Thanks, this was the type of confirmation I needed. :) I understand now, and this may be closed.
