What is this? Recognize it? Used for?
  • Thread starter Thread starter Bill Foster
The discussion revolves around the identification and potential uses of an unknown device depicted in an image. Participants speculate on its purpose, origins, and design, with a focus on its mechanical features and possible applications in various contexts, including physical therapy, microscopy, and other creative uses.
  • Some participants suggest the device was used in physical therapy for certain injuries, while others humorously imply it could cause injuries.
  • One participant proposes it is a microscope focusing stand, while another expresses skepticism about this identification.
  • Several contributions speculate on its design, with mentions of notches for tensioning materials and potential uses for launching rubber bands or lifting objects.
  • There are claims that the device was custom designed for specific tasks, including capturing birds or installing bearings in car mufflers.
  • Participants discuss the materials and construction of the device, noting its all-metal design and patina, suggesting it is not a recent creation.
  • Some participants express confusion and frustration over the device's purpose, with one remarking on its apparent uselessness.
  • Others speculate on its historical context and potential interest to future archaeologists.
The discussion features multiple competing views regarding the device's identity and purpose, with no consensus reached among participants. Various hypotheses are presented, but disagreements remain about its actual function and design.
Participants express uncertainty about the device's intended use, with several assumptions made about its mechanical features and historical context. The discussion includes references to specific design elements that may indicate its function, but these interpretations vary widely.
Individuals interested in mechanical devices, historical tools, or those curious about obscure objects may find this discussion engaging.
  • #31
The upper arm is immobile. The chain attaches to something which leads into the box. I imagine that when the chain is pulled, it pulls that lower arm up, against spring loaded tension from inside the box.
Whatever it's meant to hold, it cannot be too heavy, or the whole thing will tip over, given the moment arm since it looks like it's mean to hold it at the top of the shaft. So a beaker full of liquid is out of the question.
  • #32
The beaker would likely only hold a tiny amount.
  • #33
I don't see how a beaker would attach to those arms anyway.
  • #34
This thread could be a lot more interesting to an archeologist from the future than the object itself... A civilisation sinking in an ocean of useless stuff looking nonetheless for some meaning and purpose to what it did not so long ago...
  • #35
My attachment says it all. :wink:
Similar to:
  • #36
[P I T A]
Nice try - when was brass declared a resistive material? Musta missed that one.
[/P I T A] - had to edit the dummy dumb-xxx psuedo-code tags because of the "filter" on three letter words that mean butt.
[/color]
I feel just as confused as ever.
  • #37
zoom in and you'll see the strip (resistive material) isn't attached to the brass. maybe. :-p
  • #38
PS: I thought the profanity filter worked generally on four letter words. --- is a word that means diminuative cousin of the horse. Missed that. Of course --- hole would be descriptive but a real problem in post.
  • #39
dlgoff said:
zoom in and you'll see the strip isn't attached to the brass. maybe. :-p
I think the technical term for what you all seem to think of as brass is, actually, "muck". And as materials go, this is immensly resistive, at least to cleaning.
My guess is that this photo shows HÄGAR, an unsucessful prototype of a new IKEA lamp.
  • #40
1.Search around in the dusty corners of your lab for broken bits of ancient equipment.
2.Lay the bits out on a bench and look at them with a thoughtful expression.
3.Choose some of the bits so that you have an eclectic mixture.
4.Cobble the chosen bits together to make a random structure.
5.Take a photograph of your handiwork and send it to PF under the heading:
What the ____ Is that?--- part 2.:smile:
  • #41
You all haven't identified this contraption yet?
  • #42
I already guessed what it is. The others just haven't admitted I'm right. :biggrin:
