Chiral symmetry and quark condensate
The discussion revolves around chiral symmetry in Quantum Chromodynamics (QCD) and its implications for the quark condensate. Participants explore the conditions under which spontaneous symmetry breaking occurs and the relationship between chiral symmetry and the vacuum expectation value of the quark bilinear operator.
  • One participant questions whether the condition of chiral symmetry being an exact symmetry of QCD implies that the vacuum expectation value of the quark bilinear operator, \(\langle 0 | \bar{\psi}\psi |0\rangle\), must equal zero.
  • Another participant asserts that \(\langle 0 | \bar{\psi}\psi |0\rangle\) is not invariant under chiral symmetry, providing a transformation example involving the up and down quarks as Dirac spinors.
  • A later reply clarifies that if the theory is invariant under chiral symmetry, then the only invariant value for \(\langle \bar{\psi}\psi\rangle\) is zero, suggesting that any non-zero value would lead to a change under the transformation.
Participants express differing views on the implications of chiral symmetry for the quark condensate. While some agree on the non-invariance of \(\langle \bar{\psi}\psi\rangle\) under chiral transformations, the question of whether this leads to a definitive conclusion about the vacuum expectation value remains unresolved.
The discussion includes assumptions about the invariance of the vacuum state under chiral symmetry and the implications of this invariance for the quark condensate. The mathematical steps to derive these implications are not fully resolved.
Einj
I'm studying chiral symmetry in QCD. I understand that in order for a spontaneous symmetry breaking to occur, there must be some state with a vacuum expectation value different from zero. My question is: can someone prove that is the chiral symmetry is an exact symmetry of the QCD then necessarily:
$$\langle 0 | \bar{\psi}\psi |0\rangle = 0$$
In understand that this has to be derived from the invariance of the vacuum but I can't prove it explicitely.
Thanks
Thanks
It's actually easy to see that [itex]\langle 0 | \bar{\psi}\psi |0\rangle[/itex] is not invariant under chiral symmetry. For QCD with one flavor,
[tex]\psi = \begin{pmatrix} u \\ d \end{pmatrix},[/tex]
where we can consider the up and down quarks [itex]u,d[/itex] as Dirac spinors. Then we can write the chiral symmetry as
[tex]\psi \rightarrow \exp\left[i\gamma^5 \left( \vec{\theta}\cdot\vec{\tau}\right) \right] \psi,[/tex]
where the [itex]\vec{\tau}[/itex] are the generators of [itex]SU(2)[/itex] flavor transformations.
Some algebra will show that the kinetic term [itex]\bar{\psi} \gamma^\mu\partial_\mu \psi[/itex] is chiral invariant, but [itex]\bar{\psi} \psi[/itex] is not, because the [itex]\gamma^5[/itex] in the chiral transformation anticommutes with the factor of [itex]\gamma^0[/itex] in the Dirac conjugate.
Ok, I knew that. Actually my question was a little bit different (or maybe it's the same thing but I can't see it :-p). I was asking: IF the theory is invariant under chiral symmetry (i.e. the vacuum state is invariant) how can I show that necessarily [itex]\langle \bar{\psi}\psi\rangle=0[/itex]??
Zero is the only value that is invariant under the chiral symmetry. You can be as explicit as you like by picking a one-parameter transformation and using the [itex]u,d[/itex] parameterization. Show that, if [itex]\rho = \langle \bar{\psi}\psi\rangle_0[/itex], then [itex]\delta\rho \neq 0[/itex] unless [itex]\rho =0[/itex].
  • · Replies 16 ·
  • · Replies 38 ·
