Understanding Dirac Delta Function: Time Derivative & Hankel Transformation
femiadeyemi
Hi All,
I have a problem in understanding the concept of dirac delta function. Let say I have a function, q(r,z,t) and its defined as q(r,z,t)= δ(t)Q(r,z), where δ(t) is dirac delta function and Q(r,z) is just the spatial distribution.
My question are:
1. How can I find the time derivative of this function, that is, \frac{\partial q(r,z,t)}{\partial t}?
2. will hankel transformation of \frac{\partial q(r,z,t)}{\partial t} be equal to zero (even when Q(r,z) \neq 0)?
Thank you in advance.
FM
https://www.physicsforums.com/showthread.php?t=372548
The delta function is actually a distribution, and is not differentiable in the classical sense. In order to consider such differentiation, we have to revert to generalized derivatives. This is done by assuming a certain level of differentiability on f and some vanishing conditions.
-- Kreizhn (post #2)
Hi Simon,
Thanks for your response. Unfortunately, I'm still not totally clear. Can you please be more explicity.
Once again, thank you.
FM
Did you read the link?
Yes, I did, but I didn't fully grasp it. Anyway, this is what I can come up with, please take a look and let me know if it makes (physical) sense.
Definition: q(r,z,t)=δ(t)Q(r,z)
\frac{\partial q(r,z,t)}{\partial t} = Q(r,z) \frac{d}{dt}[δ(t)]
\frac{\partial q(r,z,t)}{\partial t} = Q(r,z) δ^{'}(t)
\frac{\partial q(r,z,t)}{\partial t} = Q(r,z) \frac{t}{t} δ^{'}(t)
since: x δ^{'}(x) = -δ(x)
Hence,
\frac{\partial q(r,z,t)}{\partial t} = -\frac{Q(r,z)}{t} δ(t)
Thank you for your help
FM
Did you understand it well enough to grasp what a "distribution" or "generalized function" is?
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
