Could the Big Bang Be a Result of Black Hole Cycles?
The discussion explores the hypothesis that the Big Bang could be a recurring event resulting from the cycles of black holes consuming matter and collapsing. Participants examine the mechanics of black holes, their role in galaxies, and the implications for cosmological models.
  • Some participants propose that the Big Bang could be a cyclical event triggered by black holes collapsing after consuming their galaxies.
  • Others argue that black holes do not "eat" everything around them, as their gravitational influence is based solely on mass, and replacing a star with a black hole of equal mass would not change the orbits of surrounding objects.
  • It is noted that black holes lose mass over time due to Hawking Radiation, which leads to their eventual evaporation.
  • A participant questions whether black holes explode upon reaching a critical mass, to which others clarify that any explosion would be minimal after most of the mass has been lost.
  • Some participants discuss the concept of finite 'bangs' emerging from black holes when torsion is included in the Einstein stress-energy tensor, suggesting a connection to other universes.
  • One participant shares a speculative idea involving tachyons and black hole evaporation, suggesting that tachyons could influence the timeline of the universe's creation.
Participants express differing views on the mechanics of black holes and their implications for the Big Bang. There is no consensus on the cyclical nature of the universe or the specifics of black hole behavior.
Some claims rely on specific assumptions about black hole behavior and cosmological models that may not be universally accepted. The discussion includes speculative ideas that are not part of mainstream cosmology.
sdgmcdon
I'm certainly no scientist, but I've always had an interest in Physics & Astronomy, so I read a bit here and there, watch primarily science shows on TV etc...Just an interest.
I was wondering though, and figured on a site called "Physics Forums" there may be a physicist or two running around here that could clear something up for me.
Every time I hear of ideas about the big bang, I never hear of one that, to my scientifically untrained mind, just makes sense; why couldn't the big bang just be an event that happens over and over again as a result of black holes being formed, "eating" everything (including each other), then collapsing in on itself (once only one remains) and POOF, another big bang?
Haven't we pretty much come to the conclusion at this point that black holes are likely at the center of every galaxy? If so, wouldn't that mean that they are consuming their galaxies?
So, you get the bang, nebula(s) & stars form, then some stars collapse creating black holes, other stars/systems begin to orbit them and form galaxies. The black holes at the center of those galaxies eventually consume the entire galaxy and through gravity and time (obviously, a LOT of time) eventually the only things left are black holes that collide / consume each other etc until just one remains and the "weight" of all matter in the universe (which would remain constant through every "bang", expansion/collapse phase) is just enough to cause the last super massive black hole to collapse in on itself and BANG, another big bang. Repeat.
Why not? Why couldn't this process occur over hundreds of billions or even trillions of years time?
Space news on Phys.org
Because black holes don't work like this.
1. They don't "eat" everything around them. If you were to magically replace the Sun with a black hole of equal mass the orbits of all objects in the solar system would be unaffected. This is because gravity is based solely off of mass. With equal mass comes equal gravity. The difference between a black hole and the Sun would be the size and density. The Sun is 1.3 million km in diameter, while a black hole of equal mass would be about 3 km across. This is important because 3 km from the center of the Sun most of the mass is equally distributed around you and spread over millions of cubic kilometers. 3 km from a black hole ALL of the mass is in front of you and gravity is pulling on you with incredible force.
2. Black holes should actually shrink over long periods of time as they lose mass from Hawking Radiation. Eventually they should evaporate completely.
Don't black holes explode once they evaporate to a critical level tho?
More like a whimper than a bang. They are probably stable until they approach the Planck mass.
Lets say you want a black hole to be at the microwave background temperature ~3K
that translates to a mass on the order of 10^-23 kg! Even if directly converting that to pure energy (not exactly how Hawking Radiation works) gives you ~5 TeV in total... not very spectacular in terms of bangs...
Just for a reference: LHC had 7 TeV center of momentum energies.
Cosmic rays are bombarding our atmosphere with energies up to 10^20 eVs !(without you even noticing...)
First they shrink and give off almost all of their mass over a long period of time. By the time they "explode" over 99% of their mass and energy are gone. Not much of a boom at all.
A black hole cannot shed mass until its 'temperature' falls below the CMB background temperature.
We have a FAQ about this: https://www.physicsforums.com/showthread.php?t=506992
I stumbled across a recent research paper in which finite 'bangs' emerge when torsion [a type of curvature mathematically associated with particle spin] is included in the Einstein stress energy tensor...and such also describes the possibility of universes being spawned from black holes and even embedded inside them as well... with connections [wormholes] to other universes...
But so far, no one knows with any certainty what started any bangs...neither infinite nor finite...
https://www.physicsforums.com/showthread.php?t=664451
Cosmology with torsion: An alternative to cosmic inflation
http://arxiv.org/abs/1007.0587 So while not a 'mainstream' [widely popular] cosmological model, such descriptions cannot be ruled out entirely...and are interesting enough to some scientists for current research and publication.
I've been toying with this conceptually for a while for a short story. So, I took BH evaporation, Tachyons, and the Big Bang and shoved them altogether for no reason other than it seemed elegant. The idea was that the acceleration of matter as it fell past the event horizon shifted some of the particles to a different energy state and spawned tachyons. Tachyons which by default travel faster than light, cause(d) the black hole to evaporate into the past instead of the present where nothing escapes.
If time didn't exist until the Big Bang, then all of the tachyons that have been or ever will be produced will travel through an ever collapsing universe to a Zero point. The energy of all of the tachyons ever created smashing into one point in time cause(d) the universe spawning explosion.
If time is a measure of linear forward progression, it doesn't matter that 2 tachyons could be created billions of years apart, they would still reach the Zero point at the same instant. This is analogus to the Galileo expirement of dropping two weights of different mass.
I was also toying with throwing dark matter in there as well but couldn't come up with an explanation of how to see the effects of a particle that doesn't exist when you measure it, but exists before you do.
I thoroughly enjoyed those articles in that thread Naty I highly recommend ppl to read them . Even though it may or may not be BB multiverses the underlying methodology on torsion was informative.
  • · Replies 19 ·
  • · Replies 25 ·
  • · Replies 53 ·
  • · Replies 20 ·
  • · Replies 49 ·
  • · Replies 17 ·
