Thickness of Graphene: Theory & Measurement
  • Context: Undergrad
  • Thread starter Thread starter kevinisfrom
    Graphene Thickness
The discussion revolves around the theoretical thickness of single-layer graphene, exploring both its atomic structure and measurement challenges. Participants inquire about the thickness in Angstroms and the interlayer spacing in graphite, while addressing the complexities involved in defining and measuring thickness in this context.
  • Some participants propose that a single layer of graphene is one atom thick, specifically referring to carbon.
  • There is a request for the thickness of graphene in Angstroms, with a mention that a carbon atom measures approximately 1.54 Angstroms.
  • One participant emphasizes that a carbon atom is not the same as graphene and seeks clarification on the thickness of graphene itself.
  • Another participant suggests that the definition of thickness is complex and depends on how one relates it to actual distances within the material.
  • Some participants mention that the thickness may be influenced by the nature of sp2 bonding between carbon atoms, which differs from isolated atoms.
  • A participant notes that while there is a widely accepted theoretical value for graphene's thickness, it is complicated by factors such as atom-atom interactions and measurement techniques like AFM.
  • One participant offers a naive approach to estimating thickness based on C-C bond length, while acknowledging that this is a simplification and may not align with AFM measurements due to changes in electronic configuration.
Participants do not reach a consensus on the exact theoretical thickness of graphene, with multiple competing views and uncertainties regarding definitions and measurement techniques remaining evident throughout the discussion.
Limitations include the ambiguity in defining "thickness," the dependence on measurement techniques like AFM, and the complexities introduced by atomic interactions and bonding types.
kevinisfrom
Hello,
I was just wondering what the theoretical thickness of single layer graphene is?
Thanks in advance for any feedback.
A single layer of graphene would be one atom thick, carbon.
Do you know the answer in Angstroms?
1 Angstrom is .0000000001 meters, carbon is 1.54 Angstroms
a carbon atom is not the same thing as graphene. do you know the thickness of graphene in Angstroms?
A carbon atom is not the same thing as graphene but a "sheet" of carbon atoms is. 1 layer thick sheet of graphene is one atom thick. Wrap it in a cylinder, you have a carbon nanotube, put it in a ball you have a buckyball, stack one sheet of graphene on one sheet of graphene you have graphite. I could be wrong, I am no expert.
Hi Greg, thank you for the reply. Your link is an experimental paper. I was hoping for the theoretical value of graphene's thickness, and also the interlayer spacing between graphene sheets in graphite.
There are sp2 bonds between C atoms. It's different from an isolated atom.
kevinisfrom said:
Hello,
Thickness is a confusing quantity. You should define how you relate thickness of something with actual length between two particular points in that something.
Again this depends on what is the definition of thickness.
AFM depends on Coulombic repulsion to measure thickness. Its hard to tell exactly where is the surface of the layer. Or how do you define the surface of the layer.
True in a sense. The "thickness" of graphene is one carbon atom "thick".
Thanks for the replys. I know there is a widely accepted theoretical value for the thickness, considering all the atom-atom interactions and whatnot. It's just a number. I understand there is a lot to consider when doing AFM scans, but there should be a simple answer to this question theoretically. I knew it once, but have since forgotten.
I can give a very naive answer. Try C-C bond length/2 as the radius of the atom. Then the thickness becomes just C-C bond length. Of course it complicates with the nature of bonds or other elements etc.
Also, you can use non-bonding p-orbital electrons of sp2 for rough thickness calculation. Just take the mean radius of their orbital. But then again it will register different in AFM as after bonding with AFM tip, the electronic configuration might change.
  • · Replies 30 ·
