Effect of wind shear on noise propagation
The discussion centers on the effects of wind shear on sound propagation, exploring both theoretical and practical aspects. Participants seek to quantify how wind shear influences the bending of sound waves and its implications for audibility in various contexts.
  • Homework-related
  • One participant requests sources that quantify the effects of wind shear on sound propagation, noting the basic understanding that wind shear can bend sound waves.
  • Another participant discusses the relationship between the speed of sound and air movement, proposing a model involving the tilt angle of sound wave fronts due to wind shear, but expresses uncertainty about the complexity of the calculations involved.
  • A third participant reiterates the request for information on wind shear effects and provides links to Wikipedia pages that outline how wind shear can cause sound waves to refract, affecting audibility based on wind gradients and temperature variations.
  • This participant also mentions specific references that detail the mechanics of sound propagation in relation to wind shear, highlighting the importance of understanding these effects for environmental engineering applications.
  • A later reply acknowledges the provided information and indicates a need for further exploration of the topic through additional resources.
Participants generally agree on the basic principles of how wind shear affects sound propagation, but there is no consensus on the specific calculations or models to quantify these effects. The discussion remains unresolved regarding the complexities of the underlying mechanics.
Participants express limitations in their understanding of the mathematical modeling required to fully capture the effects of wind shear on sound propagation. There is also a recognition that the topic may require more in-depth study and exploration of existing literature.
This discussion may be of interest to environmental engineers, acoustics researchers, and anyone studying the effects of atmospheric conditions on sound propagation.
CWatters
Homework Helper
Can anyone recommend a source of information that quantifies how wind shear effects the propagation of sound/noise?
I know the basics in that wind shear either bends sound waves upwards or downwards but I'm looking for something that helps calculate the effect.
The forward or rearward tilt angle of the sound wave front due to windshear will, I think be due the difference in speed of the sound at a height above ground.
I started thinking about this but came to an impasse. I don't know whether you have been here already but these are my thoughts:
The speed of the sound over the ground is c + v, where c is the speed of sound and v is the speed the air is travelling. So, if at height h, the air speed is Δv greater than the the speed on the ground, the wave front at h will be Δv faster. I thought that it should be possible to draw a triangle and work out the angle but, of course, in this simple model, the slope would depend upon time since the sound was launched (the dimensions are wrong unless you use tΔv). The sound in the higher air will, in fact, gradually overtake the sound on the ground. In fact, of course, sound would normally originate on the ground and the path of the sound energy launched at an upward angle to the ground would follow a curved path up and over the ground wave. The simple notion of 'wave tilt' really isn't enough to solve the problem. What you really need to be doing is to equate the propagation time along the curved aerial path to the time of the slower ground wave. At some distance, these will be equal and you will get a focussing effect. At this point I decided it was too hard for a Saturday evening.
I found a lot of rather useless links concerning the effect that the wind had on the progress of Civil war battles due to sound propagation and there was a lot of arm waving on the subject but I found precious little about the actual mechanics. I did find this link, which may be a start for you. At least it manages to have some equations, diagrams and references.
Yes, Please see the following two Wiki pages for a few introductory remarks. To get intricate details of the mechanism, please see the three references shown.
"Wind shear can have a pronounced effect upon sound propagation in the lower atmosphere, where waves can be "bent" by refraction phenomenon. The audibility of sounds from distant sources, such as thunder or gunshots, is very dependent on the amount of shear."
http://en.wikipedia.org/wiki/Wind_shear
"Effects due to wind shear
The speed of sound varies with temperature. Since temperature and sound velocity normally decrease with increasing altitude, sound is refracted upward, away from listeners on the ground, creating an acoustic shadow at some distance from the source.[2] Wind shear of 4 m•s−1•km−1 can produce refraction equal to a typical temperature lapse rate of 7.5 °C/km.[5] Higher values of wind gradient will refract sound downward toward the surface in the downwind direction,[6] eliminating the acoustic shadow on the downwind side. This will increase the audibility of sounds downwind. This downwind refraction effect occurs because there is a wind gradient; the sound is not being carried along by the wind.[7]
5. Uman, Martin (1984). Lightning. New York: Dover Publications. ISBN 0-486-64575-4.
6. Volland, Hans (1995). Handbook of Atmospheric Electrodynamics. Boca Raton: CRC Press. p. 22. ISBN 0-8493-8647-0.
7. Singal, S. (2005). Noise Pollution and Control Strategy. Alpha Science International, Ltd. p. 7. ISBN 1-84265-237-0. "It may be seen that refraction effects occur only because there is a wind gradient and it is not due to the result of sound being convected along by the wind."
http://en.wikipedia.org/wiki/Speed_of_sound
Note: These data are typically used by environmental engineers while assessing sound propagation from noise sources that may pollute habitable spaces.
Cheers,
Bobbywhy
Thanks for that. I can see I'm going to have to take a trip to a good book shop.
  • · Replies 34 ·
  • · Replies 69 ·
18K
  • · Replies 19 ·
  • · Replies 22 ·
  • · Replies 18 ·
