Quantifying the statistical error in a counting experiment
The discussion focuses on quantifying statistical error in a counting experiment involving decay channels A and B. The branching ratio is defined as BR_a = (N_a)/(N_a + N_b), where N_a and N_b represent the counts from each channel. If the experiment is conducted multiple times, the results for BR_a follow a binomial distribution. For a single experiment, N_a and N_b can be treated as independent Poisson processes, and the statistical error can be calculated using the formula N_A + - sqrt{N_A} when the total number of decays is fixed.
  • Understanding of Poisson processes
  • Familiarity with binomial distribution
  • Knowledge of statistical error calculation
  • Basic concepts of decay channels in physics
  • Study Poisson distribution and its applications in counting experiments
  • Learn about binomial distribution and its relevance to branching ratios
  • Research statistical error estimation techniques in experimental physics
  • Explore fixed sample size methodologies in decay experiments
Physicists, statisticians, and researchers involved in experimental design and analysis, particularly in fields related to particle decay and statistical methods in physics.
JoePhysicsNut
I need to find the statistical error in a counting experiment. Specifically, a decay can proceed via option A or option B and I need to find the branching ratio BR_a=(N_a)/(N_a+N_b). If I were to do this counting experiment multiple times my results for BR_a would follow the binomial distribution since there are two decay channels.
How do I quantify the statistical error in my result given that I conduct the experiment only once?
Do you have a fixed number of decays ("I take data until I have 100 decays in those two channels")?
No => you can treat N_a and N_b as the result of independent Poisson processes.
Yes => the denominator is fixed, and N_a comes from a binomial distribution.
The usual statistical error gives N_A+ - sqrt{N_A}.
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 17 ·
