Understanding Free Body Diagrams for Cantilevered Structures
The discussion focuses on drawing a free body diagram (FBD) for a cantilevered structure supporting a pulley. Participants agree that at the fixed end, there are vertical and horizontal reaction forces, as well as a moment due to the cantilever nature. There is debate regarding whether the pulley exerts a moment on the structure, with some arguing it does not due to the pulley bearings, while others assert that there is a vertical and horizontal force exerted by the pulley. The importance of accurately depicting the direction and magnitude of forces in the FBD is emphasized, as incorrect representations can lead to negative values. Ultimately, the conversation highlights the need for clarity in understanding the forces and moments acting on cantilevered structures.
pyroknife
For the attached picture I need to draw a free body diagram for the structure supporting the pulley.
At the fixed end (left), there would be a vertical and horizontal reaction force as well as a moment.
I am not sure what the forces and moments would be for the part connected to the pulley. What would it look like for this situation?
You're shown some of the forces. What others are missing?
I did not show any forces in the picture.
There should be a force where the pulley is attached, but I don't know what direction that should be in.
Edit-I think there should be a reaction force where the pulley is connected in 'both' the x and y direction.
There should also be a reaction moment where it's connected.
What about the string that runs over the pulley?
The 2 forces shown are given. They act on the pulley. The problem is to draw a free body diagram for the structure.
Does the pulley exert any forces on the structure?
You've said the wall exerts a reaction force on the beam? What is it reacting to?
The wall holds the cantilever beam. It exerts a horizontal and vertical (maybe) force on the structure. It also exerts a moment because it's cantilevered.
The pulley is being held by the structure, so yes, it exerts a force which should be both in the horizontal and vertical direction. My question is if this is right and if there is a moment exerted as well.
There is no moment at the pulley, because the pulley bearings prevent this. But there is a vertical force and a horizontal force exerted by the pulley axis (spindle) on the structure.
Yes, there is a moment.
Are the bracket holding the pulley, and the pulley itself massive enough so the their masses have to be considered?
Thank you.
It seems Chestermiller and SammyS may have conflicting opinions on whether there should be a moment exerted where the pulley is attached.
"Are the bracket holding the pulley, and the pulley itself massive enough so the their masses have to be considered?" I believe the structure is what's the pulley. I have as much info as you guys, so I'm not entirely sure. Typically for shear and moment diagram (which this is) problems, we ignore mass. This is what I assumed since they don't give you mass.
I think I agree with Chestermiller that there isn't a moment exerted at where the pullley is.
Attached is what I think the free body diagram should look like.
Where the 4 arrows indicate the arbitrary reaction forces and the counter clock wise arrow represents the moment.
pyroknife said:
Thank you.
There's a moment exerted at the junction of the structure and the wall. (I thought that's what the question was asking.)
Oh no, I mean where the pulley and structure were connected. It was a dumb question.
I agree that the two forces in the figure produce a zero moment about the pulley axis.
You have correctly shown the force and moment reactions at the fixed end, but at the pulley end, although you have correctly identified the 2 forces acting there, you have incorrectly shown the direction of those forces, and you have not indicated their magnitudes. Their direction and magnitudes must be properly shown on the FBD of the frame. The direction and magnitudes of the forces on the frame at the pulley can be determined by first drawing a FBD of the pulley, and then applying Newton's 3rd law.
When you talk about 'arbitrary' reaction forces and moment at the wall, I am not sure what you mean. You can arbitrarily choose their direction, I suppose, and their true directions will be determined when the equlibrium equations are applied. But their is no arbitation on their magnitudes (unknown until the equilibrium equations are applied), and no arbitration whatsoever in the magnitude and directions of the forces at the pulley end.
If the reactions are drawn in the wrong direction, then their value will come out negative. The magnitude should still be the same. And don't say that a beam exerts a moment because its cantilever, it exerts a moment because the fixed support prevents it from wanting to rotate. What if the beam was supported by a roller or pin? Neither one of those supports have a moment reaction
A beam with a roller or pin is not cantilevered. The definition of a cantilever beam is one that is "built in" (to a wall).
