Can Diamond or Buckytube Materials Contain Electron Degenerate Matter?
  • Context: Graduate
  • Thread starter Thread starter pervect
    Electron Matter
The discussion centers on the feasibility of using diamond or buckytube materials to contain electron degenerate matter, akin to the material found in white dwarf stars. Participants explore the required pressures, achievable densities, energy requirements for compression, and potential methods for creating such conditions, with a mix of theoretical and practical considerations.
  • Some participants reference Robert Forward's suggestion that diamond could contain electron degenerate matter, questioning its validity based on material strength.
  • Concerns are raised regarding the yield strength of diamond, with claims that it is not high enough to contain such matter effectively.
  • Participants discuss the Young's modulus and yield strength of various materials, including diamond and buckytubes, noting that high Young's modulus does not equate to high yield strength.
  • Some argue that the pressure-volume relationship needs further clarification beyond simple linear models, suggesting a need for understanding bulk modulus instead.
  • One participant proposes a theoretical method of nesting shells to increase pressure containment, arguing that mechanical aspects allow for arbitrary pressure containment with sufficient low-strength materials.
  • Questions arise about the energy required for compression and how the original material's phase might influence this requirement.
  • There is speculation about whether fusion conditions could occur under the proposed pressures, particularly with hydrogen or deuterium.
Participants express differing views on the feasibility of using diamond or buckytubes for this purpose, with no consensus reached on the effectiveness of these materials or the methods proposed for achieving the necessary conditions.
Discussions include assumptions about material properties, the complexity of thick-walled vessel stress analysis, and the potential limitations of using simplistic models for pressure containment.
pervect
Staff Emeritus
Homework Helper
Insights Author
Robert Forward once suggested that diamond was strong enough to contain electron degenerate matter (white dwarf star material).
I'd like to get some basic insight into the physics. It's half for a story purpose, and half personal curiosity. Some questions I have are:
1) What sort of pressures would be required to contain electron degenerate matter. Could diamond or buckytube based materials theoretically have the strength required?
1a) I get the stress in a thin-walled pressure vessel is pressure*r/2t , which is equal to (3/2)* pressure * (volume enclosed) / (volume of vessel). Thick walled vessels are more complicated, I don't have much insight as to the peak stress for those,.
2) What sort of densities would be achievable?
3) Within a few orders of magnitude (hopefuly 1-2, but as accurate as one can get simply), how much energy/kg is required to do the compression? I suppose I'm envisioning adiabatic compression, but if there's some other reasonable model, I'd be interested in that too. Would the energy required be affected much by the original source material or phase (solid, liquid, gas, hydrogen, water, iron, for instance)? Would the source material affect the answer to 2 (achievable density)?
3a) How hot would the compressed material get?
5) Is there any known or semi-plausible method for creating this much pressure?
6) Would fusion conditions potentially occur spontaneously under these sorts of conditions if hydrogen were used? If deuterium was used? (This might give some insight into 5 as well.)
He was wrong, except in the trivial sense that one could build a diamond shell around a white dwarf. True, but one could also build a whipped-cream shell.
The yield strength of diamond is actually not very high - otherwise they could not be cut. Diamonds are hard, but not strong. Anyway, simple dimensional analysis shows this won't work: most uniform solid materials have Young's moduli of around 100 GPa, and yield strengths of 100 MPa. So they can be squeezed to about 99.9% of their size and held there by some kind of shell or vise. I'll spot you an order of magnitude for selecting optimal materials, and that gets us to 99%. We need to get to 0.1%.
Bucky tubes have a young's moduls of 1-5 Tpa (according to wiki) , and elongate 16% before the break (according to wiki).
If the curve remains inear, that's 16% for the nanotube, and the object with the lower modulus should stretch 10x more.
It's probably not linear, but I don't think a super-simple analysis can rule out the idea. Unless I made some silly error. Or wiki did.
http://en.wikipedia.org/w/index.php?title=Carbon_nanotube&oldid=536886212
A large Young's modulus doesn't help you, as that makes it worse. You need a large yield strength.
The yield strength would be the 15-53 Gpa in the wiki article, right? 16% elonation at 1 Tpa or so?
You can also gain some factor by having a thick shell -perhaps not quite as large as the volume ratio I mentioned.
Even if bucky tubes won't do the job, I'd like a better handle on the pressure volume relation than the Young's modulus linear slope, if ayone knows.
[add]
(also: would we really want the Young's modulus, or the bulk modulus? Even for the iear approximation. I think we'd want deltaV-V, not delta-L/L)
You can't increase the yield strength by adding more material. (Think about two identical concentric shells. Once the inner shell yields, so will the outer one)
If you were off by a factor of 2, maybe there would be some way to fiddle with this and make it work. And it would make a difference whether we are talking linear or volumetric moduli. But you are many orders of magnitude off.
I've been thinking about this, and I think I have a convincing (to me) and simple argument that shows that one can contain a more or less arbitrary pressure with whatever material is available (including wet tissue paper :-)). Though the material would have to be chemically inert to whatever it was supposed to contain, etc. I'm just addressing the mechanical aspects.
Lets say you design a shell that can handle say 300 bar pressure differential between the inside and outside.
You pressurize that shell to 300 bar, and put in another shell inside it. You can pressurize the interior shell to 600 bar. (300 more than the outer pressure).
As you keep nesting shells, you can increase the pressure indefinitely. 3 stacked shells support 900 bar, etc etc etc.
One rather unwiedly realization would add pumps inside the shells. Each pump would support the desired pressure differential between the shells as you added or removed material.
Mechanically, there isn't any upper limit to what pressure you can contain that I can see. You just need a lot of low strength material.
  • · Replies 69 ·
