Can Measuring One Spin Disentangle Electrons?
  • Context: Graduate
  • Thread starter Thread starter LarryS
    Example
The discussion revolves around the concept of disentangling the spins of two electrons that are initially in a singlet state and have become spatially separated. Participants explore various physical experiments and theoretical frameworks related to the disentanglement process, including the implications of distance and measurement on entangled states.
  • Some participants inquire about specific physical experiments that could disentangle the spins of two electrons, questioning the role of distance in this process.
  • There is a suggestion that a simple scattering event may not be sufficient to achieve disentanglement, raising questions about the mathematical underpinnings of such interactions.
  • Participants discuss the concept of measurement and its role in destroying entanglement, with some emphasizing that measurement itself leads to the transition from a shared state to individual states.
  • One participant proposes the Jaynes-Cummings model as an example of a continuous process of disentanglement that does not involve the measurement problem.
  • There is a debate over whether disentanglement necessarily implies decoherence, with some arguing that unitary evolution can also lead to a product state without decoherence.
  • Concerns are raised about the vagueness of the original question and the potential for misinterpretation of the term "disentangle." Some participants express uncertainty about the implications of the original poster's inquiry.
  • A later reply references a specific experiment that demonstrates how a single scattering event can induce decoherence, although its relevance to the topic of disentanglement is questioned.
Participants express multiple competing views regarding the mechanisms of disentanglement and the relationship between measurement, distance, and decoherence. The discussion remains unresolved, with no consensus on the specifics of disentangling entangled electrons.
Some participants highlight limitations in the original question, noting that it lacks specificity regarding the nature of the disentanglement process and the conditions under which it occurs. There is also a recognition that the mathematical treatment of entangled states may vary depending on the experimental setup.
LarryS
Given, say, two electrons whose spins are entangled in the singlet state. Over time, the two electrons have become somewhat spatially separated.
What would be an example of a physical experiment that disentangles the spins of two electrons?
As always, thanks in advance.
Maybe I misread this, but it isn't obvious that a simple scattering off one of the electrons would do this?
Zz.
Zz.
OK, but how does that work (mathematically) if the 2 spin-entangled electrons are now 100 miles apart?
There is collapse, and of course distance is not a factor. It goes from being 2 particles making up a system in a shared state, to 2 particles now described by individual separable states.
Or are you asking the physical basis of that operation? (which no one knows...)
It seems Heisenberg is more important than Newton in Nature's plans.
We now have two separate (individual) wave-functions instead of one single wave function (earlier) to describe the particles.
Do you know what to do if they are only 1 micron apart?
There's something I am not understanding with this whole thread. Why do you require a distance? Why electrons in particular? Why are you not getting that the very act of measurement itself destroys the entanglement? There are things here that made the original question rather baffling.
Zz.
As you probably know, a simple spin measurement "disentangles" them.
I guess you are looking for a continuous process of "disentangeling" which doesn't involve the measurement problem. I think one example would be the experimental realization of the Jaynes-Cummings model of quantum optics. Here, you have a particle and a mode of the electrical field which get entangled and disentangled periodically.
It isn't obvious to me, why a state |Bell state of an EPR pair> × |state of a scattering partner> should generally evolve such that the EPR pair is described by a product state afterwards.
Er... there's nothing that says that it HAS to be a "product state afterwards", at least in experiments.
I can show you an experiment in which just ONE single scattering event is sufficient induce decoherence:
https://www.physicsforums.com/showpost.php?p=1498616&postcount=55
Zz.
Ok, but somehow the degree of entanglement has to be reduced. Being not very familiar with scattering, this is still not obvious to me.
ZapperZ said:
I can show you an experiment in which just ONE single scattering event is sufficient induce decoherence.
This is interesting, thanks for the link! But having read only the abstract, I don't see how it applies to this thread. If I get it right, they start with an electron in superposition and let it interact with an additional electron. This leads to momentum entanglement between the two electrons and the disappearance of the interference fringes of the first electron, i.e. decoherence occurs. How does this relate to the topic which is disentanglement of two electrons?
kith said:
Ok, but somehow the degree of entanglement has to be reduced. Being not very familiar with scattering, this is still not obvious to me.This is interesting, thanks for the link! But having read only the abstract, I don't see how it applies to this thread. If I get it right, they start with an electron in superposition and let it interact with an additional electron. This leads to momentum entanglement between the two electrons and the disappearance of the interference fringes of the first electron, i.e. decoherence occurs. How does this relate to the topic which is disentanglement of two electrons?
Doesn't "disentanglement" imply decoherence? Entanglement requires maintaining coherence between the entangled entities. That's why photons are often used. They can maintain coherence over longer distances and time when compared to charged particles such as electrons.
Sure, there are varying degree of decoherence, but that experiment clearly shows that you only need an interaction with just ONE other particle for the original coherent state to be destroyed.
Zz.
No, you can also have a unitary time evolution from an entangled state to a product state. I think this is what happens in the Jaynes-Cummings model which I mentioned in my first post (and which has been realized experimentally in 1987 according to wikipedia). There, the entanglement is between a field mode and a particle.
I don't know if something similar has been done with two entangled particles. It's not hard to write down a proper quantum circuit but it may be very hard to realize it experimentally.
kith said:
No, you can also have a unitary time evolution from an entangled state to a product state (or a state with a smaller degree of entanglement). I think this is what happens in the Jaynes-Cummings model which I mentioned in my first post (and which has been realized experimentally in 1987 according to wikipedia). There, the entanglement is between a field mode and a particle.
I don't know if something similar has been done with two entangled particles. It's not hard to design a proper quantum circuit but it may be very hard to realize it experimentally.
.. and you think that this is what is meant by the OP when he mentioned "disentangles"?
Zz.
How should he know in advance? He doesn't know how to disentangle a system, so I told him about a second possibility besides the one which had already been mentioned. I'm a big fan of answering the actual question instead of offering a standard answer.
The problem with this thread is that the OP remains very vague so probably he won't benefit much from it.
Thank you all for your input. I watched the entire 20-hour Leonard Susskind YouTube lectures on Quantum Entanglement and somehow he never directly associated measuring one of the spins as "disentanglement". In one lecture, he describes (non-mathematically) a situation in which particle A is entangled with particle B and then the experimenter throws particle B into a tub of water. He states that then particle A would be entangled with all the atoms in the tub of water and ONLY WHEN particle B is brought back close to particle A to interact with it does disentanglement occur.
  • · Replies 42 ·
  • · Replies 58 ·
