Unraveling the Mystery of Hyperbolic Functions: A Mathematical Proof
The discussion centers around the mathematical proof and understanding of hyperbolic functions, specifically the definitions of sinh and cosh in terms of exponential functions. Participants explore the relationships between hyperbolic and circular trigonometric functions, as well as the historical and algebraic definitions of these functions.
  • One participant expresses difficulty in finding a mathematical proof for the definitions of hyperbolic functions: sinh = (e^x - e^(-x))/2 and cosh = (e^x + e^(-x))/2.
  • Another participant states that definitions cannot be proven and suggests that relationships can be established depending on the chosen definitions.
  • A participant notes the connection between circular and hyperbolic functions, providing identities involving complex numbers.
  • There is a discussion about the historical context of hyperbolic functions and their relation to circular trigonometric functions.
  • One participant proposes a method involving integrals to demonstrate the area under curves related to hyperbolic functions, suggesting this could serve as a proof.
  • Another participant challenges the completeness of the integral approach, indicating that it does not fully show the net area as claimed.
  • There is a question about the origin of the constant 'e' in the definitions of hyperbolic functions, with speculation on its significance in relation to differential equations.
  • A participant discusses the validity of hyperbolic functions and their connection to normal trigonometric functions through various mathematical transformations and derivatives.
Participants express differing views on the nature of definitions versus proofs, with some asserting that definitions cannot be proven while others explore ways to relate them through integrals and historical context. The discussion remains unresolved regarding the completeness of the proposed proofs and the significance of 'e' in the definitions.
Some participants mention the historical definitions of hyperbolic functions and their algebraic counterparts, indicating that the understanding of these functions may depend on the chosen definitions and contexts. There are also unresolved questions regarding the area calculations and the implications of changing the base of the hyperbolic definitions.
Calculuser
I've searched and thought on it for a long time but I couldn't find any mathematical proof or something else about the formula of hyperbolic functions. [itex]sinh=\frac{e^{x}-e^{-x}}{2},cosh=\frac{e^{x}+e^{-x}}{2}[/itex] How do I get these formulas mathematically??
This is a common definition of them, and you cannot prove definitions.
If you want to use another definition, there is some way to relate them, but that depends on your favorite definition.
cos(ix)=cosh(x), sin(ix)=isinh(x); note that even when x is complex-valued (if you've any familiarity with complex analysis), both of these identities still hold. this illustrates the basic relation between circular functions (trig functions) and the hyperbolic functions cosh, sinh, tanh, etc.
Moreover, if y=ix, cos^2(y)+sin^2(y) = 1 => cos^2(ix)+sin^2(ix) = 1 => cosh^2(x) + (i^2)*sinh^2(x) = 1 => cosh^2(x) + (-1)*sinh^2(x) = 1 => cosh^2(x) - sinh^2(x) = 1, as expected.
there is a reason these became known as hyperbolic trig functions in contrast to the circular trigonometric functions.
take a look at that figure at http://en.wikipedia.org/wiki/Hyperbolic_function .
if it's the circular trig functions, you sweep a sector with area [itex]\frac{a}{2}[/itex] under the circular curve of
[tex]x^2 + y^2 = 1[/tex]
after sweeping out a pie-shaped sector of that area with that circular curve, the point on the curve has coordinates of [itex]x=\cos(a)[/itex] and [itex]y=\sin(a)[/itex] .
with hyperbolic trig functions, you sweep a "sector" with the same area [itex]\frac{a}{2}[/itex] over the hyperbola curve of
[tex]x^2 - y^2 = 1[/tex]
after sweeping out that sector of that area with that hyperbolic curve, the point on the curve has coordinates of [itex]x=\cosh(a)[/itex] and [itex]y=\sinh(a)[/itex] .
see the similarity?
Sure, but where is the point? This was a historic definition of the hyperbolic definitions. It is possible to show that they are identical with modern, algebraic definitions of those functions.
well, try doing a couple of integrals.
this might be the reverse of what is defined and what is the consequence, but suppose you pick any [itex]a>0[/itex] and define
[tex]\cosh(a) = \frac{e^{a} + e^{-a}}{2}[/tex]
[tex]\sinh(a) = \frac{e^{a} - e^{-a}}{2}[/tex]
then find the area under this curve:
[tex]\int_{0}^{\cosh(a)} \frac{\sinh(a)}{\cosh(a)} \ x \ dx[/tex]
(that one is easy) and then subtract the area under this curve:
[tex]\int_{1}^{\cosh(a)} \sqrt{x^2 - 1} \ dx[/tex]
and do some considerable simplification, what do you think the net area would turn out to be?
nobody took me up on my question.
the answer is [itex]\frac{a}{2}[/itex].
[tex]\int_{0}^{\cosh(a)} \frac{\sinh(a)}{\cosh(a)} \ x \ dx \ - \ \int_{1}^{\cosh(a)} \sqrt{x^2 - 1} \ dx \ = \ \frac{a}{2}[/tex]
when [itex]a > 0[/itex] and
[tex]\cosh(a) \triangleq \frac{e^{a} + e^{-a}}{2}[/tex]
[tex]\sinh(a) \triangleq \frac{e^{a} - e^{-a}}{2}[/tex]
i hope that satisfies the OP's request for "proof".
You can prove them by working out the areas like I did here:
https://www.physicsforums.com/showthread.php?t=336897
it states a formula for the tough integral (which can be checked by differentiation) and that is good, but it still doesn't show that the net area (the difference of two integrals) is [itex]\frac{a}{2}[/itex].
someone should do that here using [itex]\LaTeX[/itex].
The question on the above is : How and why does ' e ' get into the definition.
Besides the fact that it is a parameter.
morrobay said:
The question on the above is : How and why does ' [itex]e[/itex] ' get into the definition.
i don't know where the original insight into this relationship comes from. i learned out of a textbook like anyone else.
it's sort of like this: a perfectly legitimate technique to solve differential equations or to integrate functions (which is really just solving a differential equation) is to guess at the answer, calculate the derivatives plug it back into the diff. eq. and see if equality results. if equality results, you have found a solution (or anti-derivative) and, depending on the order of the diff. eq., you might be done.
so here some author in some textbook is saying:
If you define the hyperbolic cosine and sine as thus:
[tex]\cosh(x) \triangleq \frac{e^{x} + e^{-x}}{2}[/tex]
[tex]\sinh(x) \triangleq \frac{e^{x} - e^{-x}}{2}[/tex]
with [itex]e[/itex] being the base to the natural logarithm, then the following are true:
[tex]\left( \cosh(a) \right)^2 - \left( \sinh(a) \right)^2 = 1[/tex]
and
the latter, at least for [itex]a > 0[/itex] . we can work out the integrals and see that this is true.
use that fact to help you interpret the drawing at http://en.wikipedia.org/wiki/File:Hyperbolic_functions-2.svg .
now, if we changed the base of the [itex]\cosh[/itex] and [itex]\sinh[/itex] definitions to something else, the first fact would continue to be true (but for another [itex]a[/itex]) since all it does is scale the x-axis. but the second fact (with the integrals) would no longer be true. it would be off by a scaling factor.
but somehow, someone had the insight to see this and guess at the relationship, and then it's just a matter of checking it to see that the guess is correct.
afterthought: other facts that are true with that definition is:
[tex]\frac{d}{dx}\cosh(x) = \sinh(x)[/tex]
and
[tex]\frac{d}{dx}\sinh(x) = \cosh(x)[/tex]
and this would not be true with just any definition.
Here is also something interesting to consider. It can be shown that [tex]\text{(1) }e^{ix}=\cos{x}+i\cdot\sin{x}[/tex] Also, [tex]\text{(2) }e^{-ix}=\cos{x}-i\cdot\sin{x}[/tex] Adding (1) and (2) together and dividing by 2 you get [tex]\cos{x}=\frac{e^{ix}+e^{-ix}}{2}[/tex] Subtracting (2) from (1) and dividing by 2 you get [tex]i\cdot\sin{x}=\frac{e^{ix}-e^{-ix}}{2}[/tex] Now, replacing x with i*x you will get [tex]\text{(3) }\cos{(ix)}=\frac{e^{x}+e^{-x}}{2}=\cosh{x}[/tex] and [tex]\text{(4) }i\cdot\sin{(ix)}=\frac{e^{-x}-e^{x}}{2}=-\sinh{x}[/tex]
If you take the base case of the hyperbola in Cartesian coordinates [itex]x^2-y^2=1[/itex] and substitute [itex]x=\cosh{\theta}=\cos(i\theta)[/itex] and [itex]y=\sinh{\theta}=-i\cdot\sin(i\theta)[/itex] you end up with the base case of the circle, [itex]\cos^{2}(i\theta)+\sin^{2}(i\theta)=1[/itex], which is always true. It also works for the exponential representation of the hyperbolic trig functions. Also, If you take the derivative of (3) with respect to x you will get (4), and if you take the derivative of (4) with respect to x you will get (3) further proving their validity. This post, along with what is shown previously in this thread show that the hyperbolic trig functions exist, are valid, and have a connection to the normal trig functions.
  • · Replies 17 ·
  • · Replies 41 ·
  • · Replies 27 ·
