Why don't dispersion occur in glass blocks?
The discussion revolves around the phenomenon of dispersion of light in glass, specifically comparing the behavior of light in glass prisms versus glass blocks. Participants explore why dispersion is more apparent in prisms and whether it occurs in glass blocks under similar conditions.
  • One participant questions why dispersion occurs in glass prisms but not in glass blocks, assuming the same angle of incidence.
  • Another participant asserts that there is no difference in dispersion based on the shape of the glass.
  • A different participant acknowledges that dispersion does occur in glass blocks but suggests it is difficult to observe.
  • One participant explains that the parallel back side of a glass block reverses the effect of dispersion, leading to a parallel outgoing beam that is displaced from the incoming beam.
  • Another participant clarifies that while a prism gives different exit angles for different frequencies, a parallel slab results in a displacement that is less noticeable.
  • One participant agrees that displacement occurs with non-parallel faces as well, emphasizing that the direction change is critical and is reversed with a slab.
Participants express differing views on the visibility and implications of dispersion in glass blocks versus prisms. There is no consensus on the clarity of dispersion in glass blocks, and the discussion remains unresolved regarding the extent and observation of this phenomenon.
Participants reference the complexity of observing dispersion in glass blocks and the role of the geometry of the glass in affecting light behavior, but do not resolve the underlying assumptions or conditions affecting their claims.
Latrommi
This question bothered me for some time.
From what i have seen in textbooks, dispersion occurs as soon as white light passes from air into a glass prism, but why not for a glass block, assuming that the angle of incidence is the same?
The standard answer for why dispersion happens in glass prism is because of the different speeds of different coloured light in glass, so why is there a difference between a glass block and a glass prism? :confused:
Science news on Phys.org
There is no difference. Dispersion does not depend upon shape of the glass.
The back side, which is parallel to the front side, reverses the effect.
Not exactly. When light passes through a parallel slab the outgoing beam is parallel to the incoming beam, but its exit point is displaced a bit from its entrance point. Due to dispersion within the slab, each frequency is displaced slightly differently.
Of course a prism gives each frequency a different exit angle, so it's much easier to see the dispersion. (Check out the link that Latrommi posted; it's not bad.)
I totally agree, but this displacement also happens with non-parallel faces. It is the effect of direction change that is critical here, and that gets reversed with a slab.
  • · Replies 207 ·
16K
