Electron in a parallel plate capacitor - finding plate's magnitude
The discussion revolves around an electron moving through a parallel plate capacitor, with specific parameters such as initial speed, length of the capacitor, and plate separation provided. Participants are tasked with determining the magnitude of the electric field within the capacitor.
  • Participants explore how to begin solving the problem, with initial thoughts on relating forces and acceleration. Questions arise regarding the identification of forces acting on the electron and the application of dynamics principles.
The conversation is ongoing, with participants discussing the application of the second law of dynamics and the identification of forces. Some guidance on using kinematics to find acceleration has been suggested, but no consensus or resolution has been reached yet.
There is a mention of uniform acceleration in the vertical direction and constant speed in the horizontal direction, indicating the need to consider these factors in the analysis. Participants are navigating the constraints of the problem without explicit solutions being provided.
vaxopy
The drawing shows an electron entering the lower left side of a parallel plate capacitor and exiting at the upper right side. The initial speed of the electron is 7.00×106 m/s. The capacitor is 2.00 cm long, and its plates are separated by 0.150 cm. Assume that the electric field between the plates is uniform everywhere and find its magnitude.
See the picture attached..
I don't really know how to start this.. (at all).
would i try to find the centripetal force of the electron, and let that equal to the plates strength?
Write the second law of dynamics.There's no centripetal force involved.
Daniel.
but how do you find its acceleration?
By identifying which forces act on the particle...??And then applying the second law of dynamics for the moving particle..??
Daniel.
Using kinematics. There is a uniform acceleration in the vertical direction; constant speed in the horizontal. Find the acceleration, then the force, then the field.
9K
15K
  • · Replies 18 ·
