Download a *Windows 95 emulator* for XP ?
  • Thread starter Thread starter bomba923
The discussion centers around finding a Windows 95 emulator that can be used on a Windows XP system. Participants explore various methods to run a specific program that does not function correctly under Windows XP's compatibility settings, including suggestions for emulation and potential workarounds.
  • Homework-related
  • One participant seeks a Windows 95 emulator for Windows XP, stating that compatibility options do not work for their specific program.
  • Another participant suggests using Windows XP's compatibility tools by right-clicking the executable, although this is met with skepticism regarding its effectiveness for the program in question.
  • A participant mentions the possibility of editing install files if the installation program is causing issues, while also suggesting a dual boot setup with Windows 95 as an alternative.
  • One suggestion is to use DOSBox as a potential solution for running older software.
  • Another participant discusses the importance of having the necessary Windows 95 DLLs and other dependencies, warning about "DLL hell" causing installation problems.
  • There is a discussion about how to edit install files, with some participants noting that some setup programs may have plain text control files, while others may be more complex.
  • Concerns are raised about the potential impact of adding DLLs to the system32 folder and whether it could affect the XP system, with suggestions to keep them in the application directory instead.
  • Participants highlight the need to identify any required registry entries for the program to function correctly.
Participants express differing opinions on the effectiveness of compatibility tools and the best approach to running the program. There is no consensus on a single solution, and multiple strategies are proposed without agreement on which is most effective.
Participants note the potential complications of editing install files and the importance of ensuring that necessary DLLs are available. There is also uncertainty regarding the implications of modifying system files and registry entries.
This discussion may be useful for users attempting to run legacy software on modern operating systems, particularly those interested in emulation and compatibility issues.
bomba923
Where can I download a *Windows 95 emulator* for XP ?
I use Windows XP Pro, and it has program compatibility options.
However, these don't work for my case (it just won't work!).
Where can I download a *Windows 95 emulator* for use on XP?
Computer science news on Phys.org
WinXP has compatibility tools. You can run a program like it was windows 95. Just right click the exe and goto the tab.
I know I know---but the compatibility tools don't work for this program I'm trying to install! I set everything to windows 95 compatibility mode, but the program refuses to install! It somehow "knows" I'm really using Windows XP OS...:eek:
So where can I download a *Windows 95 emulator* for use on XP ??
If it is the install program itself that is complaining, then you might be able to edit the install files.
If it is XP complaining about some illegal operation the program wants to perform then you may or may not be out of luck depending on the exact operation.
You could set up a dual boot system and boot to Win95 to run your program.
erm, just do this...
Make sure you have all Win95 DLL's and anything else you think your exe installer might use (most of them go in your system32 folder or in the folder of your installer). Dll hell causes a lot of problems.
Good idea---but how do I edit the install files? There are only DLL's and JPG images and icons, and the setup application
How to edit?
Can I place them in there without affecting my XP system?
How to edit?
Some Setup programs have a plain text control file.
An exec only setup is more difficult. Also more fun :biggrin:
Sure. As long as there are no existing files of that name.
Or you could keep them in the application directory and update the path parameter to include that directory.
One big problem is if the program requires registry entries.
You need to find out what they are.
Put it somewhere, click on it, see what happens.
  • · Replies 32 ·
12K
  • · Replies 51 ·
