What Are the Key Differences Between Viscosity and Upthrust in Liquids?
  • Context: Undergrad
  • Thread starter Thread starter Cheman
    Upthrust Viscosity
The discussion centers on the differences between viscosity and upthrust in liquids, exploring their underlying mechanisms and the role of forces involved. The scope includes theoretical explanations and conceptual clarifications regarding these phenomena in both liquids and gases.
  • One participant suggests that both viscosity and upthrust rely on electrostatic effects, questioning the differences between the two forces.
  • Another participant argues that electrostatic effects are not necessary to explain viscosity and upthrust, emphasizing the importance of molecular collisions and mechanical principles.
  • A participant raises the point that collisions between particles imply electrostatic interactions, noting that particles do not physically touch during collisions.
  • In response, another participant agrees that electrostatic forces are fundamental but states that they are not needed for basic explanations, referencing Archimedes' work as an example of historical understanding without electrical theory.
  • One participant distinguishes viscosity as an energy redistribution phenomenon that occurs without external forces, while upthrust is described as dependent on external fields, such as gravity.
Participants express differing views on the necessity of electrostatic effects in explaining viscosity and upthrust. There is no consensus on the role of these forces, and the discussion remains unresolved regarding the fundamental nature of these phenomena.
Participants reference various principles from mechanics and thermodynamics, but the discussion does not resolve the implications of these principles on the definitions and interactions of viscosity and upthrust.
Cheman
Viscosity and Upthrust...
Viscosity and upthrust are both forces which occur in liquids, and must both rely on electrostatic effects. So what is there difference between them? What causes these 2 distinctly different effects?
Thanks in advance. :smile:
none of the really rely on the electrostatic effects. That means that we do not need to know anything about electricity to explain them. What is important is that the liquid molecules may collide to each other.
The upthrust comes from the fact that liquid has no shape. So at the equilibrium the pressure on the piece of liquid is the same in all directions. That is pure mechanics, the potential, elastic and kinetic energy are players there.
The viscosity comes from thermodynamic. The important player in this game is thermal energy. Now the process becomes irreversible. That is kind of tricky and non-trivial- you need to use reversible mechanical equation to introduce irreversibility. Without going into deep, you may just use known thermodynamical equations. Friction heats.
Both viscousity and upthrust exist in gases, too.
But surely it must be an electrostatic effect if it relies on collisions? Afterall, particles when they collide do not actually touch as we often depict them classically ( unless traveling ridiculously fast, eg - after passing through a particle accelerator.) but simply experience repulsion effects.
yes, of course it is electrostatic because we know that there is no other force responsible. But we don't need to know that to explain these effects. Archimedes knew nothing about the Coulomb. The problems are limited the mechanics and thermodynamics, no theory of electricity is needed (in a first approximation).
But if we are working with high energies, when atom and molecules can break down, then yes, we need to know the nature of the binding forces. At low energies only the intermolecular forces are important, and, in the first approximations, we can explain almost everything if we simply assume elastic collisions of solid structures.
I probably got your question.
The viscosity is an energy redistribution between constituents. It exists without any external force or field. The upthrust exist only if we have an external field- there is no upthrust without gravitation.
Viscosity appears because of the internal degrees of freedom of the macroscopic body. Upthrust is due to the interaction of the macroscopic body with the external field.
17K
  • · Replies 25 ·
  • · Replies 34 ·
10K
