Prove Cauchy sequence & find bounds on limit
The discussion focuses on proving that the sequence \(x_1, x_2, x_3, \ldots\) is a Cauchy sequence under the condition \(|x_k - x_{k-1}| < 10^{-k}\) for all \(k \geq 2\). The triangle inequality is utilized to establish that \(|a_n - a_m| < \epsilon\), where \(\epsilon\) can be defined using the series \(\sum_{i=0}^{l} 10^{m+l-i}\). The initial term is given as \(x_1 = 2\), and the discussion seeks to determine the bounds on the limit of the sequence based on this Cauchy property.
  • Understanding of Cauchy sequences
  • Familiarity with the triangle inequality
  • Basic knowledge of series convergence
  • Proficiency in mathematical notation and limits
  • Study the properties of Cauchy sequences in real analysis
  • Learn about convergence criteria for sequences
  • Explore the implications of the triangle inequality in proofs
  • Research bounds on limits of convergent sequences
Mathematicians, students of real analysis, and anyone interested in understanding the properties of sequences and convergence in mathematical contexts.
*melinda*
Here's the problem statement:
Prove that [itex]x_1,x_2,x_3,...[/itex] is a Cauchy sequence if it has the property that [itex]|x_k-x_{k-1}|<10^{-k}[/itex] for all [itex]k=2,3,4,...[/itex]. If [itex]x_1=2[/itex], what are the bounds on the limit of the sequence?
Someone suggested that I use the triangle inequality as follows:
let [itex]n=m+l[/itex]
[tex]|a_n-a_m|=|a_{m+l}-a_m|[/tex]
[tex]|a_{m+l}-a_m|\leq |a_{m+l}-a_{m+l-1}|+|a_{m+l-1}-a_{m+l-2}|+...+|a_{m+1}-a_m|[/tex]
Now by hypothesis, [itex]|a_k-a_{k-1}|<10^{-k}[/itex], so
[tex]|a_{m+l}-a_m|<10^{-(m+l)}+10^{-(m+l-1)}+...+10^{-(m+1)}[/tex].
It looks like we have an [itex]\epsilon[/itex] such that [itex]|a_n-a_m|<\epsilon[/itex]. Before we get to the bounds on the limit, is that correct? Is anything missing?
You might take it a little further:
[tex]|a_{m+l}-a_m|<\sum_{i=0}^l 10^{m+l-i}[/tex]
[tex]|a_n-a_m|<\sum_{i=0}^{n-m} 10^{n-i}[/tex]
I'll let a real mathematician help you the rest of the way.
