Water depth pressure against air pressure
The discussion centers on the interaction between water depth pressure and air pressure in a siphoning scenario. In a container filled with water, a smaller container submerged within it can affect water flow through a siphon based on the air pressure inside the smaller container. If the air pressure in the smaller container exceeds the water pressure in the siphon, water cannot enter; conversely, if the air pressure is lower, water will flow until pressures equalize. This highlights the critical balance between air and water pressure in siphoning applications.
  • Understanding of hydrostatic pressure principles
  • Knowledge of siphon mechanics
  • Familiarity with air pressure concepts
  • Basic fluid dynamics
  • Research hydrostatic pressure calculations
  • Study the mechanics of siphons in fluid systems
  • Explore the effects of air pressure on fluid flow
  • Investigate applications of fluid dynamics in engineering
Students, engineers, and hobbyists interested in fluid mechanics, particularly those exploring siphoning techniques and the effects of pressure in fluid systems.
pragmaticindulgence
In a ten foot by 6 inch tall container filled with water were to have another container secured in it midway but had the pressure of air in it, (the bottom is open), if the smaller container has a siphon into it could you siphon in more water, or would the pressure that keeps the water from going up into it also keep the flow of water from the siphon from entering?
Also no air can get into the siphon, but will have the force of more water and air pressure on it, so it won't let in the air from the smaller container.
If the air pressure in that container is greater than the water pressure in the siphon, no water will get in. If it is lower, it will until the pressures equalize.
  • · Replies 27 ·
