How Much Effort is Needed to Move a 2000 lb Object 50 ft?
  • Thread starter Thread starter 9000_red
    Figure
The discussion revolves around calculating the effort required to move a 2000 lb object over a distance of 50 feet, with considerations of friction and the mechanics involved in horizontal versus vertical movement.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants explore the relationship between the weight of a person and the effort needed to move a heavy object, questioning the relevance of the person's weight in the context of work done. There are attempts to calculate work using different approaches, including considerations of friction and the mechanics of horizontal movement.
The discussion includes differing viewpoints on the concept of work in physics, particularly regarding horizontal movement and the role of friction. Some participants suggest that no work is done when moving horizontally without friction, while others are seeking clarification on how to quantify the effort needed in practical terms.
Participants express varying levels of confidence in their mathematical abilities and understanding of physics concepts, indicating a need for foundational clarification. There is an acknowledgment that friction may significantly impact the calculations, but some participants are inclined to ignore it for simplicity.
9000_red
let's say a 180 lbs person needs to move a 2000 lbs object 50 feet. that would take 100,000 ft/lbs. how do you apply that in terms of how much effort it would take from a 180lbs man? divide by 180 and get 555.5? how do you determine the amount of force required to get this object rolling? this doesn't have to be exact, so friction etc doesn't have to be taken into account for my purposes...
I don't see how the person's weight has anything to do with it.
Looks to me like you have learned some formulas, but no concepts!
Moving a 2000 lb. object 50 feet horizontally would not require 100000 ft-lbs of work. Ignoring friction, it would require no work at all. Moving it 50 feet vertically upward would require 100000 ft-lbs of work because it would have acquired 100000 ft-lbs of potential energy.
i'm trying to figure out how much effort it takes for a man to pull a pallet of cokes (2000lbs) from one point in a grocery store to another (50ft). if the pallet is moved by a jack with polyurethane wheels across smooth concrete, or tile floors like in wal-mart, the friction coefficient would be
Hardrubber on Concrete f = 0,01 -0,02m
but I'm no math whiz, honestly i suck at most of it... but what's the simplest way to say it would take a guy _ lbs of effort to get this pallet rolling...
bump 4 help
HINT: Calculate how much work is done by the force of friction.
As I said before, if you are moving something horzontally and ignore friction, there will be no work done at all. All the work in this problem depends on the friction.
  • · Replies 28 ·
