Magnetic dipole moment homework
The discussion revolves around determining the magnetic dipole moment of a uniformly charged sphere rotating about its center with a given angular velocity. Participants explore the implications of charge density and integration methods in the context of magnetic dipole moment calculations.
  • Participants suggest dividing the sphere into rings to calculate the magnetic dipole moment, questioning the integration methods and the resulting expressions. There is discussion about the differences in results and the parameters used in the calculations, particularly regarding the integration limits and the definitions of angles in spherical coordinates.
The discussion is active, with participants sharing their approaches and questioning each other's methods. Some have provided partial calculations and are seeking clarification on specific steps, while others are exploring different interpretations of the problem setup.
Some participants note differences in their approaches based on whether the sphere has a uniform volume charge density or a uniform surface charge. There is also mention of potential discrepancies in the integration techniques and the resulting expressions for the magnetic dipole moment.
thenewbosco
Hello, i have absolutely no clue on how to start this one:
a sphere of radius R has a uniform volume charge density [tex]\rho[/tex].
Determine the magnetic dipole moment of the sphere when it rotates as a rigid body with angular velocity [tex]\omega[/tex] about an axis through its center.
thanks for the help on this one
Maybe you can divide the sphere into many rings. Each ring is a magnetic dipole moment, which magnitude is
[tex]\mu = iA[/tex]
Then integrate them.
By the way, what's the given answer?
Is it
[tex]\frac{4}{15} \rho \omega \pi R^5[/tex] ?
hello, i do not have the answer at this time, but i tried your method you describe and got the same as you without the 15 in the denominator. can you explain how you ended up with 4/15?
thanks
Hi. There was R^5 and sin^3 in my integration so it ended up with 4/15. It seems that we have some difference from the start. If we use the same idea, it should come out the same result. Can you post you equation?
Thanks
heres what i have done:
since [tex]dV \rho = dq[/tex] and [tex]dt=\frac{2\pi}{\omega}[/tex] so that [tex]I=\frac{dq}{dt}=\frac{dV\omega\rho}{2\pi}[/tex]
now since magnetic moment is [tex]\mu=IA[/tex] i wrote [tex]d\mu = \frac{dV\omega\rho}{2\pi}dA[/tex] then for a sphere the differential volume element i used was [tex]dV= r^2 sin\theta dr d\theta d\phi[/tex]
putting this all together i have
[tex]\mu = \frac{\omega\rho}{2\pi}\int_{0}^{R}r^2 dr\int_{0}^{\pi}sin\theta d\theta\int_{0}^{2\pi}d\phi\int dA[/tex]
where [tex]\int dA = volume of sphere = \frac{4}{3}\pi r^3[/tex]
This is the difference.
I think that we can obtain a circle by intersecting a plan and the sphere. There are many many diffrential rings on the circle, each has area
[tex]r^2 sin^2 \phi \pi[/tex]
A bigger ring will involve a small one, so
[tex]\int dA \neq \frac{4}{3} \pi R^3[/tex]
My solution is similar as yours:
A ring has charge
[tex]q=2 \pi r sin \phi r d \phi dr \rho[/tex]
so each ring has
[tex]i=2 \pi r sin \phi r d \phi dr \rho \frac{\omega}{2 \pi}[/tex]
magnetic moment [tex]\mu = iA[/tex] [tex]A =r^2 sin^2 \phi[/tex]
put this all together
[tex]\mu = \rho \omega \pi \int_{0}^{R}\int_{0}^{\pi} r^4 sin^3 \phi dr d \phi[/tex]
i am wondering what angle phi is on yours, i have used phi and theta as in spherical polar coordinates, while you have only theta. can you describe what this is. thanks
[tex]\theta_{yours} = \phi_{mine}[/tex]:smile:
[tex]\int_{0}^{2 \pi} d \phi_{yours} = 2 \pi_{mine}[/tex]
I'm not 100% sure whether my solution and answer are right or not.
If you have other ideas or know the correct answer, please tell me.
Thanks a lot
just wondering how you have for area that
[tex]A=r^2 sin^2\phi[/tex]
otherwise your solution looks right to me
Psi-String said:
magnetic moment [tex]\mu = iA[/tex] [tex]A=r^2 sin^2 \phi[/tex]
Oh I'm sorry! It should be
[tex]A= r^2 sin^2 \phi \pi[/tex]
Sorry for mistake.
(sorry for all the greek letters in superscript, I don't know why it's doing that...)
I am doing this same question except the sphere only carries a uniform surface charge [tex]\sigma[/tex]. I then obtain the final answer
[tex]4/3[/tex][tex]\pi[/tex]R[tex]\omega\sigma[/tex]
Which is equivalent to
Volume of Sphere x [tex]\omega\sigma[/tex] (+z direction)
Would this be the correct answer?
The only real difference when doing the question is that I only needed to integrate wrt theta instead of over the whole volume since all the charge lies on the surface.
the correct answer is 1/3*q*(R^2)*w ... now calculate it correctly ...
  • · Replies 25 ·
  • · Replies 16 ·
